Yep, I already know about the loss I'll have to take in mounting it in the rear, but like I said, I don't really have much choice because I have to keep A/C and fans. I've even thought about remounting the A/C unit in the rear, but that seemed to be even more trouble, and cooling would be a definite issue. I don't think the loss will be as big as people make it out to sound though, as it will be only another maybe four to five feet of pipe. With a good design on the header and the least amount of curves (and there should not be much), I think the flow can be kept pretty good. Design will be key to overcome the length issue; kind of like the difference with a log style and a tubular style turbo header. The log is obviously shorter, but yet it does not perform as well as a tubular design. Add to that 4-2-1 bonus, and I think it will be okay. Bottom line again is that I just don't really have much choice.
I have a solid platform to start with, as phase 1 of my project was a bottom end rebuild, so I am using forged internals, copper gasket, and studs. I've measured it at the junkyard, and I'm pretty sure I can get a DSM SMIC in my front fenderwell for initial cooling. I'm toying with some other cooling ideas for later, but it should be enough for starters.
I've briefly looked into the Megasquirt, but I will research it some more. Again, all that will depend on the sucess of the OBD conversion, as I want this to be completely street legal.
