Results 1 to 20 of 20
Thread: flip flop trunk trunk lights shaved
    DX User 2dsei's Avatar
    Apr 2005
    1989 honda accord sei
    cocoa florida
    flip flop trunks are very easy to do and cheap cost under 10 dollors and look really sharp i have done it if any on would like to now and ill post a how to i am in the middle of shaving te tail lighs off my truck will post how to after finished
    I do almost all my work own work and what i cant handle i help to do it
    sporkHSP's Avatar
    Oct 2003
    87LX / 86LXiHB / 90CRXSi(b16a) all gone... 91CRXSi(b16a) ...round two
    St. Louis, MO
    post pics, lets see whatcha got?
    garagement racing
    stlhondas.com
    Apr 2005
    cocoa florida
    Apr 2005
    cocoa florida
    here are some pics ill post the pics on shaving my tail lights when i start the project
    Jan 2004
    Bucket
    Bay Area, CA
    crazy! not my style, but
    Quote Originally Posted by paris hilton
    that's hooottt
    3geez for life.
    LXi User Mattphi's Avatar
    Jul 2003
    88' Accord LXI
    Jax, FL
    Yea i did mine too, however the trunk would not sit flush whenever it was shut. I dunno, it looked cool up but i just ended up putting the trunk back on stock. Post up a how to with some pics if u could n that would really help us out alot. LOL
    Feb 2003
    1950 Plymouth daily driver, 1967 Riviera, 1951 Buick Roadmaster with a 455
    Spokane WA
    I have seen that done many times, but is there a way to make it powerd and by remote? just an interesting idea i had
    Busted_Blue's Avatar
    Jul 2003
    93 civic
    San Francisco, CA
    wow...uhm..this is put right next to lamborghini doors. Just a question, does this mod give you less clearance on the opening cause that would suck considering I use my trunk for stuff (bodies, rims, etc)
    LXi User b8er's Avatar
    1987 Ex-i 89 SE-i
    Kelowna, British Columbia
    yea iv seen pictures of that mod and iv always wondering about clearence for loading stuff in and out and what not, so yea do you lose/gain any room for loading by doing this?
    -Who needs horse power when you got icy roads and bald tires
    -To drift a car is to create reckless art
    3Geez Veteran gfrg88's Avatar
    1986 Honda Prelude 2.0Si-T
    A Mile High.
    i think u can with that u can have how he has it and also put up like a stock one not very sure though
    -Gio
    My E85 Turbo Build
    5280FEST
    Apr 2005
    cocoa florida
    no it does not add or delete from truck space it is only like that when you take the two bolts out if you dont put them oin you cant close the trunk because the trunk bace of the trunk pops up i will get some pics today and do alittle how to
    SEi User danronian's Avatar
    1989 Honda Accord Lx-i, 1975 Chevrolet Malibu Classic
    Boyertown, PA
    If that picture is of the trunk lid in the fully raised position it does look like it gives you less vertical clearance when the trunk is open than with the lid normal. If you look from the bottom of the lights to the trunk that doesn't look like as much height as it should have with the trunk stock.
    Feb 2003
    Spokane WA
    those trunks can be latched in the stock position with a bolt and a cotter pin so that it functions as normal. So when gettin groceries you can still get the food ( and the bodies lol) into the trunk just fine.
    weres the how to. Looks tight
    from the pix of that white car with it, looks like i wouldnt be able to get my sub box out of the trunk if i had a flip flop conversion.
    Aug 2004
    Dude that body part made me laugh so much. How to up yet?
    For Sale:
    T3/T4 Turbo, wastegate, and BOV
    P75 ECU
    Untouched Head
    Port & Polished, 5-angle valve job, bowl and swirl job, Head -$1000 invested in machining alone
    Misc.
    DDR Pad and DDR Extreme
    PS1
    NES
    Needed:
    Dremel
    Money
    Apr 2005
    cocoa florida
    here are some pics of the hinge setup i decide to weld mine but you can use bolts and nuts to the bottom factory bolt will stay inplace so dont mess that hole up you will need it to beable to shut your trunk and have it stay closed once removed the truck will flip down it will take two people to do this project for the hinge go to a home improvement store (home depot or lows etc.) get the barn door type hinges they look like two triangles get a sturty set other wise the will bend remove the bolts to take the trunk off one side then bolt or weld on end to the hinge flat head bolt to the hinge then put the bottom bolt back in and bolt or weld the hinge to the trunk repeat for other side then get some pipe strapping and mesure frome the spring to the upper part or the car bend in 90 degree and screw to car for the tab to hold the truck up when flipped down
    Apr 2005
    cocoa florida
    LX User mr eff's Avatar
    Apr 2004
    89 Lx-i
    Berkeley, CA
    [editor's note: this is not to be rude, but intended to make 2dsei's information more accessible. hope it helps]
    here are some pics of the hinge setup.
    i decided to weld mine, but you can use nuts and bolts. the bottom factory bolt will stay in place, so don't mess that hole up; you'll need it to be able to shut your trunk and have it stay closed. once removed, the trunk will flip down.
    it will take two people to do this project. for the hinge, go to a home improvement store (home depot, lowes, etc.). get the barn door type hinges--they look like two triangles. get a sturdy set, otherwise they will bend.
    remove the bolts to take the trunk off one side, then bolt or weld one end to the hinge's flat head. then put the bottom bolt back in and weld the hinge to the trunk deck. repeat for the other side.
    get some pipe strapping and measure from the spring to the upper part of the car. bend the piping 90 degrees and screw it to the car. this will hold the trunk up when flipped down.
    Quote Originally Posted by 2dsei
    Chris
    click the car to see my picture archives
  1. Flip Flop Trunk
    By Mattphi in forum Interior & Exterior Care
    Last Post: 01-28-2004, 07:06 PM
  2. flip top trunk
    By zchb9 in forum Interior & Exterior Care
    Last Post: 12-31-2003, 12:00 PM
  3. E-Bay's "Flip Flop Trunk" modification????
    By Chrome_thangs in forum Classic Honda Community Chat
    Last Post: 10-06-2002, 11:38 PM
  4. Shaved trunk and tail lights
    By Chrome_thangs in forum Interior & Exterior Care
    Last Post: 05-15-2002, 04:59 PM
  5. The "flip - flop" trunk thing
    By accordlx in forum 3geez Accords
    Last Post: 05-06-2002, 04:11 AM
