Results 1 to 14 of 14
Thread: Hole in firewall?
    2.0Si User pimp86LX's Avatar
    2005 Mazda 3
    Ontario Canada eh.
    Hole in firewall?
    k, i am curious as to wer eyou guys ran your power cable. I can't find any plugs or holes in the firewall that i can run my 4g wire through...helppp!!
    does your AC works?
    If it doesn't there is a hole you can use. on the passenger side under the dash you should be able to find rubber hose which is going outside that hose for AC condensation stuff.
    if you don't use it, rip it off and run the power cable on passenger side and audio cables on driver side. this way you won't have any problem with noise in your speakes.
    2005 Mazda 3
    Ontario Canada eh.
    yeah the ac works :-(
    1989 Accord LX-i Hatchback
    Western NY
    dude...lift up your passenger carpet...there should be a rubber grommet...there was in my car...so there might be for yours...
    www.geocities.com/geezpict/bumb
    87 LX ; 86 Chevy Camaro
    Ma.
    I just drilled a whole on the passenger side under the glovebox, cable went under the carpet easiy with no buldges and is on the battery side of the car so it all works out nicely.
    D-mAn..the guy with the reallly clean all-stock 87 LX and still pimpin it. :pimp:
    make sure you don't drill into anything.
    1988 Honda Accord LX
    Virginia
    On the drivers side of the firewall I found a rubber plug and I punched it through. It comes out behind the pedals. I then ran the wire across the firewall. It comes put perfect to go under the carpet. Good luck! I can e-mail you some pictures if you need them.
    2005 Mazda 3
    Ontario Canada eh.
    thanks man. i really was hoping not to go over to the other side, but it seems preferable to drilling. but...i don't know if i should butt-end connect to my exisiting 4g wire (that cost $20) to get the remaining required length or buy a whole new 4g wire.
    Also, i'm going to run a distribution block. right now the block runs to just around the ecu..do you guys think i could mount the block on the ecu case?? i was wondering if its best to keep the block closer to the amps or something like that...anyway..i'll see what i come up with
    2005 Mazda 3
    Ontario Canada eh.
    Look at me! the active thread
    89cordlx's Avatar
    Black 1989 LX-I Coupe and 2000 EX V6 coupe
    Westerville, Ohio
    in my car I had a hole allready in the firewall right like right under the glovebox (if you lift up the carpet.) Thats how I ran I think 4guage wire when I had my 10's.
    Check my cardomain for sale items! Cardomain
    2005 Mazda 3
    Ontario Canada eh.
    well, today i ripped out my passenger side dash and didn't find any holes that could fit wires. I only found 3, which i assume was for the harness, the heater core and something else. so i ran the 4g wire through the drivers side and to the back seat to a distribution block. it fit soo nicely
    thanks for the help guys, i'll get some pics in a little while
    Feb 2002
    89 Accord LX
    Bend, OR
    i just drilled a hole right under the glove box on the passenger side and i have the amp under the passenger seat... sounds nice... put some silicone around the wire after you run it through to keep it in place and stop air/water leaks.....
    88 Accord (Australian Model Si)
    GoldCoast, Australia
    IS 6 GAUGE larger than 8 GAUGE?
    Feb 2002
    89 Accord LX
    Bend, OR
    the smaller the number, the bigger the wire.... so yes, a 6 gauge is bigger than an 8 gauge
  1. wire to battery thru firewall
    By 88accordSF in forum Interior & Exterior Care
    Last Post: 07-16-2007, 08:37 PM
  2. Power wire through firewall?
    By propr'one in forum Classic Honda Community Chat
    Last Post: 12-07-2006, 08:25 AM
  3. Oil All over the firewall behind carb
    By ehulst in forum 3geez Accords
    Last Post: 08-28-2004, 08:12 AM
  4. Firewall ports
    By 3rdGenFanatic in forum 3geez Accords
    Last Post: 07-25-2003, 01:11 AM
  5. Hole in Firewall
    By xbi0s in forum Interior & Exterior Care
    Last Post: 03-20-2003, 06:51 PM
