Results 1 to 1 of 1
Thread: Trembling????
    Honda Accord 4D Lxi
    Red face Trembling????
    Hi! Problem again!
    My friend's 3G, 1987, 4D, 4AT, Lxi, run 150kmiles. Now the problem is trembling. Trembling when condition as below: A/C "on", fan "on" and no matter level 1 or 4, shift at "D4" but step on brake when traffic light in "red", it will be more badly if the generator of A/C is working or while the power windows is working. We ever fine turned the idle speed to increase from 850RPM to almost 1000RPM, which do a little help but not cure. It is quite stable when shift at "N" or "P" and everything is "off". Some service shop advised us to replace new engine mounts, does it work? Or it is else problems beside the engine mounts?
