Ive been looking through these forums for quite a while now but i cant really find any info on this. When doing turbo what do you do with all the vacuum? I see that some people remove the vacuum box and all the lines, but doesnt that make he car run like shit? and what exactly do you remove and what do you leave?
also questoin about some of the people running the legend injectors. If injectors are specially designed per car and you are running the injectors from the 2.7 CL like I read somewhere on here and you do the math
CL
2.7L / 6 cylinders you get = .45 flow through into each cylinder.
Accord
2.0L / 4 cylinders you get = .5 flow through the injectors.
wouldnt that mean if you used the CL injectors you would actually be down sizing? even if you did a 3.0L
3.0L / 6 cylinder you will still only be equal to the accord. SO am I thinking wrong here?
I have many more questions but if I can we start with these
