ok, well i've been having trouble with my fuel filter that's in the engine compartment. i had put a view through one in. then maybe 3 weeks ago i replaced it with another one that had universal fittings. the fittings are plastic that screw into the metal ends on it. anyway, i used teflon tape and tightened the fittings well, not overly tight. it would mainly leak from just one end. dunno why. then today i noticed it leaked from around the part where the glass is sealed with a rubber gasket to the metal end. i tightened that and it didnt leak, but the fitting was still leaking even after i used teflon tape. i even wrapped it correctly, counter clockwise so it wont slip off when its being screwed in. anyway, i decided to say screw it and got a oem type replacement. seemed to fix my problem! so could it be my fuel pump is pushing too much pressure? also can too much fuel pressure cause bad gas mileage? i'm getting between 19-21mpg. i can add a pressure regulator easily. my fuel pump is a replacement pump, not original.
