Results 1 to 6 of 6
Thread: My clutch exploded
    LX User 895spdforfree's Avatar
    Aug 2004
    Exclamation My clutch exploded
    well not really but its gone. I was going to lunch today at school and halfway to jack in the crack i floored it in like 3rd gear to pas a car and i did right...well i got to the light and when it turned green, it didnt want to go into gear. Well i then realized my clutch is FUC*Ed and yeah..
    Well what would be the easiest way to replace my clutch? Im trying to do it within 2 days. I really need my car so yeah any tips would be great.
    ( i used search but i got lazy sorry)
    thanks
    uhhhh
    Aug 2004
    bummmp
    uhhhh
    shepherd79's Avatar
    Falling Waters, WV USA
    sorry, there aren't any easy way to replace the clutch. you would know that if you did the search.
    snoopyloopy's Avatar
    Killa Cali
    pwn
    Feb 2004
    89 accord lxi
    down by the bay
    well you can save some time by not entirely removing the axles. just pop out the inboard cv joints from the diff by turning the knuckles all the way to the right or left for each side and then kind of swing them out of the way. also, the radius rod doesn't have to be removed. you can unbolt it from the lower arm and it should have enough play to get the tranny around when you drop it. that should save a little time.
    the only thing to really make it easy is practice; meaning you've done it before. the first time will always be kind of slow and tricky.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Here is the link how to re-place the clutch .. Good luck with it.
  1. My clutch exploded
    By 895spdforfree in forum EFI Tech
    Last Post: 06-03-2005, 10:15 PM
  2. Exploded view of KEIHIN ED07A
    By kilgorq in forum Carburetor Tech
    Last Post: 02-21-2005, 10:28 PM
  3. Tranny Exploded!!! Need Info On B20
    By SIBILANTx in forum General Engine Swaps
    Last Post: 01-25-2005, 12:13 PM
  4. Exploded View Schematics The Dealership Uses
    By BootMachine in forum Performance
    Last Post: 01-10-2004, 08:34 AM
  5. tranny exploded and diff fucked
    By mugenprelude86 in forum 3geez Accords
    Last Post: 08-02-2003, 06:56 PM
