Well I've been dabbling into programming for windows... and I got to thinking what if I make a program to at least map out readings from:
- Wideband A/F gauge
- RPM
- Fuel PSI
- Manifold Vaccum hg
*Dependng if the Carb has ports for these*
-- Pri-Sec Port Vaccum hg
-- Pri-Sec Throttle Vaccum hg
-- Pri-Sec Venturi Vaccum hg
*If I can get the basics working I may add this*
--- Throttle Position Sensor
Problem is I can do simple programs in windows... but I have no clue how to make something that will give output and how to make a program that will interpret the input and then display it.
I was basicly wanting to make a carb tuning box... that will then need a laptop to be useful or I guess it could store the data somehow so you could move it to the desktop.
I know digital vacuum gauges exist, and wideband O2's I can get, I already have a tach... I just don't know what I need to pull data from the voltage singals thay put out.
Any help would be appreciated
