Results 1 to 18 of 18
Thread: Drag Only exhaust!
    LX User Civvy's Avatar
    Mar 2004
    18 yr old Prelude, the one with the pop up headlamps. B20 (prototype for the 3g Prelude) ...but in the lighter car, with big brakes
    Pommieland
    Talking Drag Only exhaust!
    O.k. i use my nice quiet exhaust for the street but for drag i fancy something with a little more rasp to it.
    Idea is to remove the wheel well from the trunk and replace with sheet aluminium (also good for weight mods)
    Remove the stock fuel tank and use my fuel cell on the rear seat/trunk.
    thus giving me a straight OBSTICLE FREE run to the rear of the car.
    I'm thinking i can just run a long piece of straight pipe from the turbo to the rear.
    and thats it.
    Comments
    Nov 2002
    Ridin Dirty in New York
    just have the exhaust end in a turndown before the gas tank
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Are you alowed to do side exit?
    Like by the rear wheel or behind the front wheel
    It's not the best chop but it works.
    Nov 2002
    if you want REAL power just go open header. Seriously ive seen guys drop almost .5 sec off their ET just by going open header... yes, it was on a honda
    LXi User b8er's Avatar
    1987 Ex-i 89 SE-i
    Kelowna, British Columbia
    well iv been around drag racing since i was 8 years old and it mostly been with dragsters and american cars but yea il back epicenter up iv seen both amrican/import cars drop time from just an open header
    -Who needs horse power when you got icy roads and bald tires
    -To drift a car is to create reckless art
    Nov 2002
    or you can run a cutout right at the header flange so you can run a full exhaust or open it up. Ive been running the turboaccord with just an open downpipe right under the engine... its not as loud as youd think and the cops havent given me shit, although if i didnt have a turbo itd be loud as all get up
    Aug 2004
    Quote Originally Posted by A20A1
    yeah from the header exit flange all you have to do is run a pipe with less then 30 degree angle (I think any steeper angle is when you start to run into losing exhaust velocity) straight out the side. Just make sure that you don't end it right under your feet! It will start to get really really warm and your feet will start to feel nice and toasty which is not a good thing!
    For Sale:
    T3/T4 Turbo, wastegate, and BOV
    P75 ECU
    Untouched Head
    Port & Polished, 5-angle valve job, bowl and swirl job, Head -$1000 invested in machining alone
    Misc.
    DDR Pad and DDR Extreme
    PS1
    NES
    Needed:
    Dremel
    Money
    Mar 2004
    Pommieland
    I'm scared of flames igniting my fuel tank thas all. yea side exit is allowed, but it involves bends and more money.
    Talking of running open manifold, this is only if we got a compressor wheel right?
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    I think at a track there's no noise restriction. You could probably drive the car to the track. Unbolt the exhaust at the end of the header, run it, put the exhaust back on and drive home. Should be fine turbo or not.
    Mar 2004
    Pommieland
    I asked because i'm thinking we'll loose backpressure for the n.a. guys!?
    Justin86's Avatar
    Medford, Oregon
    yea for the NA guys you loose backpressure, but if they have a properly designed header it won't madder. All the power is made in the header the exhaust is just a means of transporting the gases to a safe loacation, just make sure the exhaust isn't smaller then the header collector. backpressure I'd say is good for a street car but for all out drag their engines runs best with out a restrictive exhaust
    Aug 2003
    1989 Honda Accord LX
    Bowling Green, KY
    Quote Originally Posted by Civvy
    and thats it.
    Comments
    http://www.jegs.com/cgi-bin/ncommerc...cgrfnbr=158876
    You would have to up the size of your exhaust, but personally I like the Mr. Gasket ones, you mount the cable in the car, give it a pull, and you have open exhaust whereever you put the cutout...
    just a thought.
    Robby Klotz
    Bowling Green, KY.
    3G'less at the moment. Working on getting an LXi
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    yeah dude i would just run a cutout or side dump. i dont see much point it geting fuel cell and removing gas tank, and going to all that trouble, if your too cheap to spend some money on ehuahst bends lol
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    shes not cheap.....she just doesnt want to lose power on exhaust bends......its for drag racing, read the post before you flame
    '89 SE-i Coupe
    Awaiting Garage
    bobafett's Avatar
    Longview, WA
    uh huh..... and i would still run a side dump or a cutout rather than run a fucking exhaust tube down the entire length of hte car, even if it is straight...
    think about it before you tell me to read the post... oh and btw
    by civvy
    she is also concerned with the MONEEEEEEEEEEEEEEEEEEEEEEEY you see...
    and even though it has bends, IMO (and no im not a professional drag racer, so its not like im more right than anyone else in this thread) running a cutout or a side dump, will get more power than a straight thru exhaust to the back of the car.
    ESPECCCCCCCCCIALY with turbo (which im under the impression this is designed for)
    Justin86's Avatar
    Medford, Oregon
    yea for the turbo the best exhaust would be the biggest and shortest. You should be able to get a mandrel bend 3"pipe for pretty cheap and besides the downpipe will have about 2 90 deg bends in it allready. from a weight prospective it would be best to have the side dump and a fuel cell, take a look at the pro FWD cars exhaust designs.
    Mar 2004
    Pommieland
    Quote Originally Posted by RobbyKlotz
    just a thought.
    Man i love that! nvr thought of that! but then i could just disconnect the downpipe to the system?
    You reckon there's remote ones two? any links or pics??
    bobafett's Avatar
    Longview, WA
  1. DB Drag
    By Ludi Mali in forum Interior & Exterior Care
    Last Post: 11-11-2005, 06:14 AM
  2. My new toy: 90 teg drag car
    By MoonScryer in forum Classic Honda Pics & Videos
    Last Post: 02-16-2005, 12:42 PM
  3. Anybody DB Drag?
    By AccordEpicenter in forum Interior & Exterior Care
    Last Post: 03-04-2003, 10:27 AM
  4. Accord drag car
    By buzzbomber88lx in forum Performance
    Last Post: 01-09-2003, 10:45 PM
  5. Db drag
    By 89accordlxi in forum Interior & Exterior Care
    Last Post: 07-20-2002, 01:48 PM
