Results 1 to 7 of 7
Thread: Cold Air Intake horse power results
    Paul Aerodeck86's Avatar
    Jul 2001
    Accord Aerodeck 2.0 EX 1986
    Russia, Moscow
    Exclamation Air Intake +8 hp gain!
    I make "quick" home-made Air Intake (i can't say it Cold Air Intake), it's rubber tube about 10 cm (~3") long and Cone Air Filter from Honda S2000. Later i planned to make a long steel tube, it will be working more better.
    After measuring power with APEXi REV/SPEED Meter i got 133hp, with stock air - 125hp. Yes, i know power is more, that must be by tech specs, it can change, because of weather, tire resistance, temprature engine oil etc.
    P.S. My 3 top 0-100 times is changes, i easly got 08"81, 08"82, but my record 08"80 i can't beat, because i haven't time for racing :-) tryouts...
    Later i do it and you will see it on my banner.
    Oct 2001
    87 Accord EX , 5spd , Manual
    wow ! 8 HP ! i think that's real good with a 3 inch intake!!!
    MIKE
    Jul 2001
    Russia, Moscow
    It's not intresting for all??
    YK86's Avatar
    Oct 2000
    BC, Canada
    Thanks for letting us know!
    www.b20accord.com
    1989 accord LX-i,88 RX-7 Turbo II
    Toledo, Ohio
    thats a real nice gain, do you have anything else done to the motor or exhaust? i definatly felt alittle more throtle response when i put my intake on.
    88 RX-7 Turbo II...a few things
    89 Accord LX-i: too much to list
    See them both here: http://www.cardomain.com/member_pages/view_page.pl?page_id=339969
    Jul 2001
    Russia, Moscow
    I have stock engine, because i will swap it... and after this, i will be tuning other performance components...
    Sabz5150's Avatar
    1989 Accord SE-i coupe
    Richmond, VA
    Paul -
    If you install a real cold-air intake, beware of hydro-lock! If you drive into a deep enough puddle of water, the cold air will pull it right up into the engine. That's a quick way to kill a car.
    You can buy valves to prevent this though, look for air bypass valves.
    -5150
    glorious!
  1. How Much Horse Power
    By Accord7SE_i in forum Performance
    Last Post: 07-29-2003, 07:31 PM
  2. more horse power?
    By joshuabrack99 in forum Performance
    Last Post: 11-04-2002, 06:47 PM
  3. True cold air intake's VS. short ram test results
    By Jims 86LXI HB in forum Performance
    Last Post: 10-27-2002, 05:30 PM
  4. True cold air intake's VS. short ram test results
    By Jims 86LXI HB in forum Frequently Asked Questions
    Last Post: 10-27-2002, 10:16 AM
