Results 1 to 19 of 19
Thread: outer wheel nut size?
    SEi User myaccord7's Avatar
    89 honda accord LX
    Quincy,IL
    does anyone know the size of the nut that holds everything on? its the end nut that you skrew on the axle, i need to take it off to change my wheel bearings and my rotors. i have a 30mm but it was too small.
    zach
    Vinny's Avatar
    Aug 2003
    Here, not there
    Axle nut takes a 32mm Socket
    Vanilla Sky's Avatar
    1999 Penalty Box
    32 or 30mm... the ones were on my car when i did my first axle job were 32, and the ones i got when i got my new axles were 30...
    Nov 2002
    Ridin Dirty in New York
    its actually 1 1/4" but you can use a 32mm just fine
    89 honda accord LX
    Quincy,IL
    thanks
    89 honda accord LX
    Quincy,IL
    well i just got a 32mm and it seems to be alittle lose. is 1 1/4 the real size?
    zach
    Quote Originally Posted by myaccord7
    zach
    NO its metric but 1. 1/4" is very close. 32mm is 1.259" so 1.250" 1 1/4 is a snick tighter. I think 31mm is 1.220 but I belive 31mm is an oddball socket to find. The nuts usually hard to get off so be prepared. Air gun is your best bet.
    89 honda accord LX
    Quincy,IL
    i tried to get it off with the 32mm. didnt come off. any help on getting it off?
    zach
    zach
    If you dont have an air gun, then you are going to need a very long cheater bar and a big person. The key is to use leverage, stick the ratchet on with a breaker bar attached to the ratchet or stick a 4 foot long led(or something close to the same strength) pipe over your ratchet handle. From there all you can do is pull realy hard, with my old car I did a auto to 5speed swap and it a pretty big dude to get that bolt loose. Also you said you are trying to change the rotors, but that bolt dose not need to be removed in order to change the rotors. Just remove the two little screws in the rotor. Hope this helps and good luck.
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    He needs to remove the 32 mm nut to change out the wheel bearing. A socket (not a ratchet) with a breaker bar and a long (4-6') steel (not lead) pipe that fits over the handle of the breaker bar should take the nut right off. Have you bent the lip of the nut out of the notch in the end of the axle? PBlaster or a similar penetrant may help also.
    Mike
    89 honda accord LX
    Quincy,IL
    well i need to change the rotors too. im changing my wheel bearing and going to FINALLY go to try my 5speed swap.
    zach
    Quote Originally Posted by AZmike
    I am just stating what I did and worked
    89 honda accord LX
    Quincy,IL
    ok,the 32mm is too big. i dont want to round the nut. is a 31mm to small? what does the clinton manual say the real size is?
    zach
    LX User mr eff's Avatar
    Apr 2004
    89 Lx-i
    Berkeley, CA
    i used a 32 and a gun, zipped right off. sorry
    Chris
    click the car to see my picture archives
    SEi User phrenology's Avatar
    Accord 88 LXi Coupe
    Regions Unknown
    Wink
    The Clinton manual says to do it manually and use a big cigar!!! "Buddum- Bump-psh"
    I used a 32mm with an impact wrench. Good luck.
    SEi User
    Mar 2005
    swifts/sprints boosted
    Saskatoon
    Why not get a 1-1/4? Thats the actual size..
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    if its a replacement nut, it could be a different size. new axles come with new nuts and they're not always the OEM size. Sounds like you might want to try a standard size.
    Nothin' 2 Old Racing
    89 honda accord LX
    Quincy,IL
    its orig. so the 1-1/4 the actual size?
    SEi User
    Mar 2005
    Saskatoon
    Yes
  1. Outer tie rod end
    By russiankid in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-23-2008, 02:42 PM
  2. What is the best tire size for a 16x7 wheel?
    By aerokid1987 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-16-2006, 12:29 PM
  3. What's the best wheel size for my car???
    By HondaBoy334 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 12-19-2003, 05:43 PM
  4. wheel size for 87 lxi?
    By yjdave in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-30-2003, 03:15 AM
  5. Wheel Size's
    By 2Fast_Fiero in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-15-2002, 01:04 AM
