hey guys. I was just taking apart the vents and such so I could investigate why the middle switch/lever between the center vents wasn't working. I fixed everything except there is a clip that holds the cord in place on the bracket attached to the vent. The problem is the cord won't stay secure and moves around because the clip doesn't hold it properly, so in attempting to bend it I broke it. Should I just go to a junkyard and find another clip or is there a better way to secure the cable down so it doesn't move around when I attempt to flip the switch/lever? Also, I took out the sliders for the fan intensity and temperature and I found a plug in for the fan strength, but I see the temperature slider attached to nothing, and when i slide it it doesn't change the temperature. Is there a missing part or did I forget something? Should I just go to a junkyard for all this crap or what, help me out please!
