Well right now im stuck as fuck. I was putting my kybs in and taking off the rear struts which is pretty easy and took em off the first time with the quicks. well right now i tryed to loosen the bottom bolt and it broke so im like FUCK. i used a penut grider to cut off the strut and took it off. cut both ends off and drilled a hold thou. its needs to be a hair bigger so the new stud can go in. any ideas. i used state of the art drill bits from work for metal only can do so much. What esle? i tryed a punch with a 5 lbs hammer still nothing. I NEED HELP.........PLEASE....
