I noticed there are a few members here questioning how the horn button would work if we had cruise control. I decided to take on the task and make a ghetto fab to make it work.
Main Problem
The stock cruise control hub is oddly shaped. Noticed that the bottom of the hub is not flat like other non cruise control hubs. There are 3 prongs. The two parallel ones are for cruise control and the other one that is perpendicular is the horn button. Because of this, we cannot use the flat gold peice from the hub and have to use the stock one with the prongs. Now the problem with this is that the black peice will NOT spin with the Hub.
Here is the hub with the stock peice on.
So what I did was use L Brackets where I'm sure you can find at some hardware store or something. I bent the L bracket a little more to resemble more like a V so it would line up with the side of the hub. I put on the L bracket to slip onto the two bumps on the stock spinner thing. This way I don't have to secure it to just the hub and it can be removed and put back a stock steering wheel.
