Results 1 to 4 of 4
Thread: off throttle sputtering (LXI automatic)
    Oct 2003
    88 Accord LXI (low mileage engine)
    Vermont
    My 88 LXI automatic sputters sometimes when I am off the throttle and going down a hill. If I touch the gas a little, the spuddering stops. It only seems to happen when off the throttle. Oddly the car idles fine when I stop, and there are no problems with acceleration. Additionaly, when the sputter happens and I shift into neutral the car doesnt sputter anymore.
    The car was tuned up 2 years ago ( less than 22k miles ago). The plugs, cap, and rotor should be fine. Perhaps the air filter and fuel filter might be a tad dirty, but my experience suggests the latter would only cause acceleration problems or top end problems. my gas mileage is fine.
    ideas?
    Quote Originally Posted by possum
    ideas?
    there some deal with the ECU cuts power to the injectors on coast type conditions you discribe. Read up on it in the book. I think thats the surging that people feel. Its an old injection system remeber so they had some fine tuning to do.
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    When the throttle is closed and the engine is above 1200 rpm the injectors are shut off completely.
    Mike
    Nov 2000
    I get the same kind of fluctuation at times when it is hot outside. It never happens when it's below 80 degrees. I had it checked by the local Honda dealer and by a good Honda mechanic and neither could find anything wrong. I wonder sometimes if it could be related to the very high mileage transmission. Since I tried everything I knew and had it looked at by the so-called experts I had to learn to live with it.
  1. new: 87 Accord, sputtering
    By zorobyte in forum Carburetor Tech
    Last Post: 06-12-2009, 05:27 PM
  2. sputtering and a few other problems(exi/automatic)
    By newaccorddriver in forum EFI Tech
    Last Post: 06-14-2005, 09:50 PM
  3. [Engine & Transmission] Automatic Transmission, Fluid Check and Throttle Valve TV Cable Adjustment
    By Einstein in forum How To
    Last Post: 03-23-2005, 12:49 AM
  4. sputtering
    By adams86lxi in forum Classic Honda Community Chat
    Last Post: 03-11-2004, 08:34 PM
  5. Replies: 1
    Last Post: 07-09-2003, 04:51 PM
