Results 1 to 8 of 8
Thread: Annoying clicking sound...
    Feb 2005
    1989 Honda Accord LXi
    I have come to notice that a EXTREAMLY loud clicking sound is coming from under my hood. I did a search hoping to find a answer to my question and I found a answer, actually about thirty, and they were all different. So heres the deal: when I accelerate I hear a loud clicking sound. I have a 89', four door, automatic LX-I. I have not done any modifications under the hood and this sound is bugging me. Any clue to the problem. Thanks in advance.
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    can you tell maybe what general direction the sound is coming from? have you had somebody rev the engine with the hood up to see if you could tell where its coming from? Is it happening only when you're driving or when you're stopped too?
    Nothin' 2 Old Racing
    Feb 2005
    It does do it but not as loud or fast when i'm parked. I don't hear anything if say I accelerate (it clicks while i accelerate) then coast (clicking then stops) which makes me think that maybe its a engine issue. As for location I think its coming from more on the drivers side
    LX User paso100's Avatar
    Mar 2005
    1988 Accord LX-i sedan
    Central California Coast
    Sounds like you need a serious valve adjustment; last one cost me about $120. Don't wait too much longer.
    Feb 2005
    Thanks NXRACER and PASO100, I'll get on that post-haste, I get paid thurs so i will get that taken care of, if it persists after that I post back here. Thanks again.
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    sounds like your CV joint(s) might be going out too. If you have your valves adjusted, see if they can check our axles too while they're at it.
    Feb 2005
    Well i'm trying to get started and it couldnt be worse. I can't get the cam gear to TDC, the haynes book says and i quote "the preferred method is to turn the crankshaft with a socket and ratchet attched to the bolt threaded into the front of the crankshaft." Well this thing won't budge
    87 LXi Hatch (5-speed)
    Riverside, CA
    make sure the car is out of gear, and remove your spark plugs.
  1. Clicking sound, jumpy rpm
    By SFCA1987lx in forum 3geez Accords
    Last Post: 03-01-2009, 09:09 PM
  2. Clicking sound with moonroof
    By bill in forum 3geez Accords
    Last Post: 08-31-2003, 04:42 PM
  3. clicking sound with moonroof
    By bill in forum EFI Tech
    Last Post: 08-18-2003, 04:56 PM
  4. very annoying sound
    By BLck89accord in forum 3geez Accords
    Last Post: 02-15-2003, 07:22 PM
  5. Clicking sound?
    By 87DXHatch in forum Classic Honda Community Chat
    Last Post: 09-18-2002, 12:02 PM
