Results 1 to 20 of 20
Thread: dual carb
    LX User theDougler's Avatar
    92 VW Jetta
    Kelowna, BC
    dual carb
    i have a 87 accord lx with the carb. i was wondering if dual carbs from a prelude would work?
    thanx Dougie
    SEi User halxi's Avatar
    88 LX-i Coupe
    Brighton, Colorado
    if its a prelude of the same year, with an a20 yes... but i dont believe they have them, i dont know much about that sort of stuff so wait for some of the high tech guys to read this thread.
    Good luck to ya, id like to see it completed.
    Vanilla Sky's Avatar
    1999 Penalty Box
    the intake manifold bolt pattern doesn't match. for $250, you can have a manifold built for the use of weber DCOE carbs, though.
    LXi User b8er's Avatar
    1987 Ex-i 89 SE-i
    Kelowna, British Columbia
    hey doug its tyson, im thinking your outta luck ont he dual carbs, i would suggest the same as vanilla sky, from what iv read and reserche don i would say wait a bit, same some money, get DOCE carbs and the manifold to match, i believe if yuo check out the buy and sell area, there wasa guy that was selling a manifold for DOCE's, dont know if he still has it or not, but check it out, see what yuo can do
    -Who needs horse power when you got icy roads and bald tires
    -To drift a car is to create reckless art
    1999 Penalty Box
    he sold it, but he bought it from wierracing, who posted them over on honda-tech before anybody knew about them here. i have contacted the person that built the manifolds, and said he can replicate the design for $250 each, which is a bargain for the piece of art the manifolds turned out to be.
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    You'd have to swap on the prelude head onto the A20 block...
    1987 Ex-i 89 SE-i
    not that hard swaping heads over and i agree that 250 is a awsome price
    SEi User
    Jan 2004
    carbs
    get four Bike carbs fitted.
    1987 Ex-i 89 SE-i
    has anyone eveer actually just put bike carbs on?
    i have seen 4 yamaha sidedrafts on a civic swapped with a b18...was pretty damn quick.
    A20A1's Avatar
    Sep 2001
    yes,
    A20A1 in civic
    1987 Ex-i 89 SE-i
    thats pretty sweet, does anybody know how hard it was to run the throttle cables on that
    LX User Versanick's Avatar
    Jun 2002
    1986 Honda Accord LX Sedan (RIP), 1989 (same) RIP, 86 Hatch Lx-i, JDM b20a, Gude headpkg, AEM cam gears/cai, thermal xhst, 2.5/3" lowrd tokico/groundctrl, 17" Seneca whls, hypereutectic pistons, .020" over, 13:1 comp
    Upstate NY
    you can cut off the manifold flange from a prelude motor and mig weld on our flange, from the outside. sand the inside to remove any mess from the welding.
    so yes. and yes, I've done it. it's not that hard. cut carefully. our intake manifolds have REALLY crappy casting sometimes (the carb ones).. but cut off the flange, and put it on the prelude carb manifold. cut the prelude carb manifold at an angle (at the flange) if needed if it angles up or down in a strange way. shouldn't. the cylinders have the same spacing, so this isn't that rough to do.
    not worth it those are POS emissions equipped carbs and plus they're designed for a smaller displacement motor.
    Get a weber 38/38 downdraft (or a pair of sidedrafts if you have the $$)
    Eric
    SEi User
    Jan 2004
    POS Carb
    YEah right so your teling me that honda Fireblade with a 1000cc engine with well over 150bhp is going to use POS carbs!!! I don't think so, you can pickup Honda 1000cc carbs which have a 42mm bore size complete with linkages and mounts, all you nned to do is get an inlet manifold madeup, theirs been a company in the U.K that makes bike carb conversions and they regularily swap out bike carbs ontp FI cars and gain 30+bhp from 1.6l to 2.2L engines. Plus bike carbs can be re-jetted, and also if you really wanted to go made you could get some proper racing bike carbs from RS or Mikuni which have 40-50mm bore sizes and are completely adjustable. Also their's a 2G lude with a set of Bike carbs on that runs pretty good was built by the same guy who did the 2G lude drag car that runs ten second 1/4 miles so i doubt he's use crap parts some how!!
    Bike carbs have been designed and improved for performance for the last 20 years they are no doubt the best carbs that money can buy now, they are even better than DCOE's from weber but these are still easier to setup and tune for people who like to fiddle with their setups.
    LX User mr eff's Avatar
    Apr 2004
    89 Lx-i
    Berkeley, CA
    i think he was referring to the idea of using stock lude dual carbs, not ITB bike carburators
    Quote Originally Posted by POS carb
    Chris
    click the car to see my picture archives
    SEi User
    Jan 2004
    stock carbs
    Hmmm yeah stock lude carbs are POS far too small although are marginally better than stock A20A1 carb but not by much!! Even upgrading to two big newer bike carbs would be better, bu ti allways thought that one DCOE 48/50/55 would work quite well but if you gonna go to the trouble of having a new inlet manifold you might as well fit two!! or get 4 bike carbs.
    That Civic is sick wonder what times it runs and power!!
    yea I was talkiung abt the Prelude carbs, I didn't read the bike carb post... plus I figured I was the only crackhead that thought about doing that!! :b
    <edit. also if you've ever tried synchronizing two carbs, imagine four! edit>
    Eric
  1. dual carb conversion?
    By lostforawhile in forum Restoration & Custom Fabrication
    Last Post: 11-20-2006, 05:25 PM
  2. Dual Carb
    By Ludi Mali in forum Performance
    Last Post: 08-29-2004, 05:53 PM
  3. dual carb set up
    By pip in forum Carburetor Tech
    Last Post: 03-16-2004, 02:17 PM
  4. pic of a jdm b18a dual-carb
    Last Post: 12-07-2003, 06:58 PM
  5. dual carb manifold
    By mykwikcoupe in forum General Engine Swaps
    Last Post: 02-07-2003, 10:26 AM
