Results 1 to 5 of 5
Thread: ignition fights starter (kind of like dieseling?)
    in the never ending slew of problems with this car it decided one day to start preigniting but it's weird...
    if I crank the car over it struggles like when the battery is dead, the tach flies up, everything dims. If I try it once or twice more it cranks right up. If I flood the engine prior to starting it will crank normal. If I disconnect the coil-to-distributor wire it cranks normal. It definately seems the engine is preigniting somehow
    the funniest part:
    sometimes after I shut off the car (normal, no dieseling, smoke, or smells) and turn the key back to the on position the cylinders fire and the engine will spin backwards maybe 1/2 a revolution but it's a hard jolt if the car is in gear! (i.e. if I'm in a forward gear the car will lurch back, and vice-versa)
    I'm thinking I need a new distributor or something
    I have an MSD blaster coil with the stock distrib.
    I already swapped the starter.
    Eric
    NXRacer's Avatar
    86 LXi Hatch
    Tri-Cities, WA
    the weird tach action almost sounds like your valve cover ground isnt working properly. Might want to check your coil wire and coil.
    Nothin' 2 Old Racing
    Vinny's Avatar
    Aug 2003
    Here, not there
    Check your ignition switch. That was what was wrong with the coupe. It would start fine first start of the day or after it had been sitting for a while but after that it would hang up trying to turn over. I replaced the strater, the battery, the distributor, and even the head because it acted like a stuck valve at times. If you disconnected the coil it would crank over fine all day long until you reconnected the coil. Then it would go back to the fast then slow then fast then slow cranking until it caught and fired for good.
    When I took the steering column off and looked behind the key switch there was a huge gob of solder that was making it arc across the contacts. Havent had another problem since I replaced it. It fires up almost as soon as you turn they key now
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Engine going backwards? Are you plug wires hooked to the right cylinder?
    ignition switch is a possibility then b/c I USED to have problems with it not making good contact in ACC but the problem disappeared over 2 years ago...
    Yes I have the firing order correct. It's like it's igniting a gas charge inside the cylinder as soon as the key hits "on"
    Eric
  1. Dieseling/Run on
    By canadian357 in forum 3geez Accords
    Last Post: 01-28-2017, 07:28 PM
  2. ignition starter switch to push button
    By brianc85 in forum 3geez Accords
    Last Post: 03-03-2004, 01:58 PM
  3. Replies: 3
    Last Post: 02-17-2004, 02:47 PM
  4. starter? ignition swtich?!
    By xaccordx89x in forum 3geez Accords
    Last Post: 04-30-2003, 03:07 PM
  5. dieseling
    By 87accordlx in forum 3geez Accords
    Last Post: 10-28-2002, 02:09 PM
