I apologize for the title of this. It just skims on what my problem (or problems) are with my b20a. To recap, I have most of the GUDE headpackage (race cams), so vacuum is hard to get right, I THINK I have an 86 teg type dist. and cam sensor (exhaust cam thing) unit.
I had a PGM-FI light every time the car started since I got it from Josh, and I finally found code 8, we alleviated the problem (wires had rotten/worn out) with the TDC Sensor wires. Reading in Haynes (and other places) that a messed up TDC signal (or none) can very much affect your fuel injection timing (or something along those lines... how much/long your injectors open).
I still don't know if my fuel pressure regulator isn't stuck closed or something, as I've alleviated what I thought was wrong with it (running rich) from the PGM-FI warning's indication. The FPR works just the same hooked up to 0 vacuum (wrong thing plugged up to) and hooked up on the butt of the intake manifold.
On the other side of the equation, my properly-wired MSD 6AL, via my electrical system, sends INSANELY erratic RPM readings to the tach (and inserts the rev limiter sporatically, almost as close together on and off as fast as feeling like dropping a spark plug). The thing is, the HONDA tach also does the same dance (I'll post a video of this... I mean this thing FLIES to 8k, 3k, 5k, many times per second sometimes), and it's hooked up just like it should be.
Sometimes, when I had my quick-release terminal on my - side of my battery, and the tachs were going crazy, I could pop the hood and tighten the terminal and move it a little, and the problem would go away. THIS tells me I have a ground problem. Doesn't it? But now I've removed the quick-release, and put on the normal terminal (very securely... the battery is new too BTW). The problem persists. Not any better at all.
Now that the PGM-FI dillemma is fixed (besides the EGR after a while, but that's a minor thing), we can't decide why it's running rich. If the distributor itself is broken, does it to this? When the car's running fine (completely randomly), every spark sparks, and the car pulls great (would be better if it wasn't ridiculously rich). Hot or cold, it seems to work fine.
Do I have a huge ground problem that's making the injectors go crazy? A broken FPR? Dizzy? Ground problem?
I have a pj0 ECU wired to the b20a fully.... we can't figure it out.
Anyone have a clue? Or know who would?
