Results 1 to 6 of 6
Thread: 88dx mt carb question
    Jun 2005
    I broke the bottom plate on the mt carb, so its junk. Can I use an 89 automatic carb, as I have access to a rebuilt one? Thanks in advance.
    Dec 2003
    88 Accord LX 5 spd
    Warren,Ohio
    you can use the carb off the AT but you have to change the little vacuum canister on the back of the new carb (drivers side) and put the old one back on. ATs have two vacuum lines coming off MTs have only one
    The City Is Mine
    carb plate
    Quote Originally Posted by gold88dx
    when you say plate do you mean the throttle body assembly? i could sell you one reasonable i've got several
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Are you refering to a vacuum holding cannister a thermovalve or the A/C idle boost diaphragm?
    Manual and Auto carbs are the same but the vacuum wiring is a little different.
    The A/C idle boost will have 2 vacuum port... you just plug the unused vacuum port if you use the auto carb on a manual carb, no need to swap diaphragms. The diaphragm is built in layers so that you can add or remove the extra vacuum port and self convert the auto 2 port to a manual 1 port A/c idle boost. But still it's better just to plug the extra port unless you plan on rebuilding the carb.
    Do you mean the EFE plate? the brown/black plate under the carb?
    A20A1's Avatar
    Sep 2001
    The automatic carb also may use a different throttle linkage if the Throttle value cable went to the carb instread of the accelerator pedal. I pretty sure it's okay to use the auto linkage though, it wont get in the way.
    A20A1's Avatar
    Sep 2001
  1. one owner stock 88DX 4dr
    By g.frost in forum Newbie Introductions
    Last Post: 12-21-2006, 09:11 PM
  2. Got an 88DX for $200 and it runs!
    By my89dx in forum Classic Honda Community Chat
    Last Post: 09-10-2006, 12:03 AM
  3. Pictures of my 88DX Sedan
    By HostileJava in forum Classic Honda Pics & Videos
    Last Post: 09-25-2004, 10:35 PM
  4. carb question?/ auto tranny question?
    By accordlxi2.0 in forum Carburetor Tech
    Last Post: 09-25-2004, 03:01 PM
  5. FS: 88DX Hatch Phoenix Red! (black interior ladies)
    By markmdz89hatch in forum Trading Post
    Last Post: 07-18-2003, 10:23 AM
