Results 1 to 25 of 25
Thread: Full Coil-overs. Why not?!?!
    Aug 2004
    Hey guys. I know that we don't have any options for full coil-overs not the sleeve type. But my question is why won't other cars coil-overs work? I've got a friend that owns an air suspension shop and he can literally put bags on anything provided he has enough cash. I told him about my perdicament and he said that theirs no reason why id shouldn't work. It would just take some work and fabrication. So my question to all of you is why won't it work? What is preventing us from using say a 90-93 teg full coil-over? Thanks and hopefully the guys that tried it and found it didn't work will be able to put some imput into this thread.
    For Sale:
    T3/T4 Turbo, wastegate, and BOV
    P75 ECU
    Untouched Head
    Port & Polished, 5-angle valve job, bowl and swirl job, Head -$1000 invested in machining alone
    Misc.
    DDR Pad and DDR Extreme
    PS1
    NES
    Needed:
    Dremel
    Money
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    Reason being that full bodied coilovers are expensive, and most people on here probably dont have the tools or skills to make the mods needed themselves, and paying someone to do so would cost a fortune.
    Busted_Blue's Avatar
    Jul 2003
    93 civic
    San Francisco, CA
    go try out the EF civic coilovers. I know those will be the closest for our cars. The only problem is the front most likely will need brake line holders as well as new top hats for our strut mounts.
    Justin86's Avatar
    Medford, Oregon
    I all ready figured this out......... https://www.3geez.com/showthread.php?...t=civic+shocks
    the rear are a little short the the front's are taller with the civic/teg. The 4g/5g accord is the best fit but still too tall in the front. Right now NXracer is using Civic Si shocks in the rear but his hatch is slamed to the ground.
    LX User spades27's Avatar
    1989 accord ex
    toronto ontario canada
    wow sounds like a lot of work but i bet would look so sweet
    Mar 2005
    swifts/sprints boosted
    Saskatoon
    Would there be much of a performance increase over a good set of springs and struts?
    Calgary, AB, Canada
    The main benifit is the adjustability factor... I good set of full bodied coilovers lets you adjust compression and rebound, and you get the height adjustability like coilover sleeves without the shitty ass ride. The springs and shocks are also designed to work together unlike most spring/shock assemblies.
    I would think that 4th/5th gen accord coilovers would probably be the closest, but the fact the they are probably a fair bit taller would make things complicated.
    Aug 2004
    Quote Originally Posted by Hash_man_Se_i
    Exactly. That's why I was asking. Justin are you rolling on full bodied CO's?
    For Sale:
    P75 ECU
    Untouched Head
    Misc.
    PS1
    NES
    Needed:
    Dremel
    Money
    Justin86's Avatar
    Medford, Oregon
    I'm pretty happy with my current Koni reds with Eibach coils. But once I get more money I will go to a full coilover set up or at least get some 5 way adjustable shocks from the 4/5g accord.
    Jul 2003
    93 civic
    San Francisco, CA
    justin if you got the time you should try out the civic of 89-91 coilovers.
    Aug 2004
    When someone says you should try it out how do they get the part? Like are they expected to go buy it just hoping it will work? Or is there a place to get sponsered and what not? Just wondering. Kinda off topic.
    For Sale:
    P75 ECU
    Untouched Head
    Misc.
    PS1
    NES
    Needed:
    Dremel
    Money
    Jul 2003
    93 civic
    San Francisco, CA
    Quote Originally Posted by w00tw00t111
    lol... just that justin is the only person willing to try out suspension things. I dont expect him to but its always worth a shot.
    Justin86's Avatar
    Medford, Oregon
    shit I'm the one that need a sponser, or a rich grandmother.
    I can't remember what I found on the 89-91 civic but I know for sure the coils would be designed for a car that weight 500lbs less.
    Jul 2003
    93 civic
    San Francisco, CA
    Quote Originally Posted by Justin86
    The only suspension full bodied I would look at at this point would be Omnipowers. Since ALL the spring rates are identical across the board for each honda whether it is an integra, civic of all years it is either 10k 8k or 12k 10k for the car. The 12k and 10k spring rates are amazingly stiff for the CRX and the exact same setup for my friend's 95 integra with 12 and 10k feel much more refined.
    Perhaps i'll try it out once I get more funds...we'll see
    LX User geesnow's Avatar
    Jul 2004
    1988 honda accord lx-i
    richmond, VA
    carsponsorships.com--check 'em out
    Check out my family site: mysite.verizon.net/vze8kudg
    Aug 2004
    Quote Originally Posted by geesnow
    I've heard of them in magazines. Are they legit? Have you ever used them?
    For Sale:
    P75 ECU
    Untouched Head
    Misc.
    PS1
    NES
    Needed:
    Dremel
    Money
    2drSE-i's Avatar
    1989 Honda Accord SE-i Coupe
    Oklahoma City
    they sound legit, but they demand a credit card number......so id guess u pay them before anything goes down
    '89 SE-i Coupe
    Awaiting Garage
    Justin86's Avatar
    Medford, Oregon
    well long as you have choices for spring rates. thats the one thing I don't like aout most of the companies and the rate they do come with will just give our car more understeer. Mostly cause we can't get larger rear sway bars to make up for the difference.
    LX User truetune's Avatar
    Apr 2004
    1988 Honda Accord LX-i
    Jacksonville, Florida
    doesn't someone on the board have full bodied low boyz coilovers. and isn't there than one foren company that will make a custom set for anyone with 2500 in there pocket. I would gladly spend that if I had it just to get a full bodied set.
    my car is stock it just likes sittn lower to the ground than most cars:
    Lowes 3" CAI W/filter, hackd off mufflar, MSD Blaster 2 coil and bosch Platinum spark plugs&wires...she roars all the way to 6K
    Apr 2004
    I E-mailed Omnipower a week ago and asked them if they would possibly make a custom set for the Accord and they said no, none will be made at this time. if I can find someone to do it for less than say 1600 Ill gladly give them everything they need for a set of fullbodieds
    sorry to post whore but has anyone tried contacting Ground Control about this subject they alredy make sleve coilovers for our cars so whats all stoping them from makin a full bodied set they do it for mustangs and civics alredy so it can't be impossible.
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    yeah, DXHATCHBACK had the lowboyz, though I think he sold them (maybe to someone else on the board?). Truetune; you're clearly the exception on 3geez willing to spend 1500ish just for suspension--honestly hope you can find someone to work it all out for you. Realistically, there's not enough of a market for a full bodied coilovers considering it would be a huuuge stretch to get more than 50 (or even 50) people from here to buy them.
    Alex
    2drSE-i's Avatar
    Oklahoma City
    20 if we are extremely lucky
    not to rag on 3geez, but most of our members (myself included) are dead ass broke
    i have a job and am broke......lol
    '89 SE-i Coupe
    Awaiting Garage
    Calgary, AB, Canada
    Lol... im somewhat broke... but would be willing to spend the money on some teins or jics.... Ive strongly been considering buying some for a 4th gen accord and trying to make them work.
    Worse comes to worse, it wont happen and i lose a couple hundred selling them, but at least id have tried
    Justin86's Avatar
    Medford, Oregon
    thats a lot of money, you could just but a set and pay someone to make them work for cheaper. It took me a couple hours to adapt a set of civic shocks.
    Apr 2004
    I just want a good set up for my accord, and why not go for the best possible. I don't see myself getting a diffrent car for a long time so gota try and get the most out of it.
  1. full bodied coil overs vs coil over sleeves
    By newaccorddriver in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-19-2007, 11:54 AM
  2. full bodied coil overs vs coil over sleeves
    Last Post: 06-17-2007, 11:57 PM
  3. Re: PROJECT: Full bodied coil overs
    By Legend_master in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-04-2007, 03:24 PM
  4. [Suspension, Wheels, Tires & Brakes] PROJECT: Full bodied coil overs
    By Legend_master in forum How To
    Last Post: 04-20-2007, 07:28 AM
  5. Full Bodied Coil-Overs
    By markmdz89hatch in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-16-2003, 09:49 AM
