Results 1 to 3 of 3
Thread: How To Set Tokico Shocks
    Jun 2005
    2004 TL 5AT NBP
    hi all,
    i don't have an Accord (well, i have some of an Accord). i have a 2004 TL and i'm currently documenting a DIY install of SPC Camber Kit, Eibach Springs, and Tokico Illumina shocks (http://www.acuraworld.com/forums/showthread.php?t=57845).
    the shocks are adjustable 1soft - 5firm. i'm not familiar with this car in terms of setting shocks (fwd trans, etc). i dont auto-x or anything, just a daily driver that i occasionally drive a tad hard. i'm after a smooth non-bump jarring ride but i wish to have the steering as neutral as possible in terms of over/under steer (i also have the larger 22mm Comptech rear swaybar and some "sticky" Falken ST115's on 18" OZ rims).
    the rear shocks are a royal pain in the butt to do because the rear seat and crud has to come out in order to unbolt the shock tower, hence i would like to set the rear shocks before they go in.
    any suggestions on how i should set front-to-rear, perhaps 2-3 or a 1-3 ??
    any help appreciated.
    AK
    Busted_Blue's Avatar
    Jul 2003
    93 civic
    San Francisco, CA
    just leave it 1 - 1 for the soft ride
    in terms of illuminas, I've noticed that they don't really improve too much when you change the clicks. Really if you are looking for a soft comfy sporty ride, go with the first click.
    Jun 2005
    2004 TL 5AT NBP
    well, i'm also looking to neutralize under/over steer. there are 2 factors governing this problem (in terms of shock settings):
    1. the stiffness of the shock
    2. the front-to-rear differences in shock setting
    i know it's gonna be hard to get real data because i'm the 1st person using a set of Illumina shocks on a 3G TL, but i'm after the "in general" answers. i guess if i felt comfortable in knowing the answer to #2 then i could take a educated guess as to the actual settings. for example, if i can get some info that the rear should be a tad stiffer than the front, i might go with a 2-3 setting to start out with.
    thanks
    AK
  1. Tokico Blue Shocks Help, ebay
    By SharkyX in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-10-2012, 01:33 PM
  2. Rear shocks tokico
    By Maybach310 in forum For Sale
    Last Post: 11-29-2011, 05:22 PM
  3. tokico shocks swap
    By import racer in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-17-2009, 02:10 PM
  4. 2g Tokico Shocks...
    By loko84hb in forum 2geez Accords
    Last Post: 10-10-2006, 05:31 PM
  5. tokico shocks
    By 89cordlx in forum Interior & Exterior Care
    Last Post: 04-26-2003, 12:03 PM
