Results 1 to 2 of 2
Thread: Cruise control......................
    LX User bigpoppa88's Avatar
    89 EX-i, 88 Accord LX (parts car)
    Winnipeg, Manitoba, Canada
    Question Cruise control......................
    Hey, new to the list, I looked up crusie control problems in the archive but had no luck with the results. Hopefully someone has had the same problem. '88 Accord LX bought used, the cruise is not working, I replaced the vacum unit in the engine bay, the cruise switch on the dash and the fuses in the fuse box, I did these one by one and tested at each change. I'm going to replace the cruise relay way up under the dash....before I do that is there any other items to check, I looked in the chiltons manual, but it was no help.
    3Geez Veteran Bobs89LXi's Avatar
    Nov 2000
    2005 Civic LX Coupe
    Tualatin, OR
    Check both the brake pedal and clutch (if it's manual) switches. If they are not adjusted correctly or not working, your cruise will stay in a constant "disengage" mode. I would check those before replacing the more expensive items you mentioned.
  1. cruise control
    By ripcord in forum Carburetor Tech
    Last Post: 06-11-2011, 09:36 AM
  2. Cruise control?
    By Nio in forum 3geez Accords
    Last Post: 01-15-2010, 09:53 PM
  3. Cruise Control
    By 89 Ex-i in forum Classic Honda Community Chat
    Last Post: 02-07-2007, 08:03 AM
  4. Cruise Control!!!
    By kaltenacht in forum 3geez Accords
    Last Post: 05-24-2005, 01:51 PM
  5. cruise control?
    By jaiden in forum 3geez Accords
    Last Post: 03-08-2005, 01:30 PM
