I have an 87 accord lx with a 2000 cc KA carbureted engine and about 125k miles on it. I am having trouble with it starting for me, and randomly shutting down on me every once and a while. One time was while driving at about 40mph, the idle just dropped and the engine stopped running, everything else worked fine. Another was while starting it after an event that went about 4 hours, it started and then just died off; when I went back to pick it up, it didn’t start and I played with the fuse board a little it started and ran fine. I looked on other forums and they seemed to suggest that the main relay connections were bad. I tried to locate the main relay and check the soldered connections, but I don’t think there is one. I am curious if the lx version has one at all. I just replaced the fuel pump and both fuel filters within the past month or so, and I seem to be getting no gas to the carburetor. i just contacted the local honda repair garage and they said it could be the fuel pump cut-off relay, so i found a new one online and ordered it.
