Page 1 of 3 123 LastLast
Results 1 to 25 of 51
Thread: Speaker Size
    LX User 88eyeguy's Avatar
    97 Prelude, 97 Suzuki RF600R
    dallas
    Exclamation Speaker Size
    Alright, since no one seems to be able to discover the mysterious speaker size of our cars...
    DX's-
    Front: 5.25" or shallow mount 6.5" speakers.
    Rear: None
    LX's (Canada EX)-
    Rear: 6.5" speakers
    1986-1987 LXi's (Canada EXi)-
    Rear: 6.5" speakers
    1988-1989 LXi's-
    Rear: 6x9" speakers
    SEi's (Bose system)-
    Front: 3" speakers in a 6.5" mount, so 6.5" speakers will fit.
    Rear: 6x9" speakers
    Hatchbacks-
    Rear: 6.5" speakers
    In the front, most 6.5 speakers will require minor modification to the bracket and/or basket in order to fit properly without hindering the window track.
    5.25" speakers will fit up front without modification.
    The DX models are wired for speakers in the rear, however you would need to cut out the proper sized holes to drop speakers in.
    If anyone has additions/corrections, feel free to post them.
    ~Andy
    Four cars (and one motorcycle) in three years and not one with a cupholder...this is the story of my life.
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    wooot someone makje this a sticky please... and I could be wrong, but the opening for my fronts in my sei are 6.5"... so placing a 5.25" would require an adapter plate/wooden moutn
    Vanilla Sky's Avatar
    1999 Penalty Box
    the mounting flange for spekers in this car is spaced so that you will land somewhere on it with either size of speaker.
    MIK3's Avatar
    Jan 2003
    1988 Accord DX
    Phoenix, AZ
    Looks pretty good. You might just want to add that there are provided wires incase you ever wanted to throw in 6.5"s in the rear on the DX models. The only modification you need to do other then the straight install is cut the holes in the cardboard/carpet top. But the wires are definitely there for the install. And my 6.5" Infinities fit like a charm in the front, was a clean install with no modification as well. Just thought I'd throw that in, if it matters any.
    -Strugglebucket
    redaztec
    DAYUM!
    2ndGenGuy
    MessyHonda
    SEi User 87DXHatch's Avatar
    '92 Toyota Paseo
    St. Paul, MN
    To further clarify, if you have an SE-i, the front speakers are 3" in a custom ported Bose enclosure. The normal "6.5 inch" baskets will fit there after you remove the Bose stuff, but you have to get one of those from another car. Also, all of the hatches used 6.5" speakers in the back. Additionally...
    It depends how the manufacturer measures their "6.5 inch" speakers. I've had some cheap JVC "6.5 inch" speakers that were not actually 6.5". The openings in the Accord's front doors are NOT 6.5"... at least not the last time I measured them. They were 6.25" last time I measured mine, which was a year ago, as I no longer own the car.
    To get my Adire Koda 6.5" speakers (I measured them, 6.5" from edge to edge) to fit I had to construct a baltic birch spacer ring; they were too wide for the stock mounting ring. However, like I mentioned, it depends how the manufacturer measures their speakers. Some fit fine, others require modification. Just don't freak out if things don't work perfectly right away.
    The other thing to take into consideration is separation of the front and rear firing waves. You want to be as sure as you can that the speaker is SEALED OFF when you're mounting it. If you need to, use a strip of closed-cell weatherstripping around the mounting hole, so that the speaker is sealed off. Along the same train of thought, you also would benefit from sealing off all the holes in the inner door skin; all those access points allow rear-wave/front-wave interaction which reduces the amount of midbass you have.
    And yet one more thing: if you can, put something like the Deflex pads behind the speaker, attached to the outer door skins with epoxy or glue or something. I personally use a small piece of egg-crate foam, treated with scotchguard to (hopefully) prevent mold from growing. These things reduce standing waves, which can adversely affect the sound the speakers are producing.
    Any other questions, shoot me a PM.
    1988 Honda Crx Dx Mini-Me
    Columbus, Indiana
    i knew my hatch dx didn't have speakers back there!!! that stupid circuit city guy!!!!
    yeah okay so are there holes i can look for (i really have the hatch full of my backseats and the shelves right now so i can't look till i get rid of em...
    Well my fronts are like jensens and now i need to toss my rear seat and look for the wholes for some rear speakers cuz this is getting old, plus my cd player doesn't work and it resets the radio because whoever put it in didn't run a hotwire to it... if anybody has pix of their rear hatch speakers in stock location that would be greatly appreciated!
    well i went over to the guys house who i bought the car off of and turns out he's got some 5 1/4" DUB's by audiobahn... they're 80watts... $50 ... i didn't buy em...haha but anyway they fit my rears perfect i found where the stock speakers go and sure enough the wires were already there... now i need to buy some loudass speakers and toss em back there...thanx for all the info!
    1999 Penalty Box
    while it did lack rear speakers, it did have the provisions for them.
    Jul 2005
    1990 Dodge Grand Caravan SE
    East Providence, RI
    I bought my DX with speakers already in the back, never knew they it didnt come with em, someone must have put them in because there are clarions in the front doors, I replaced the back ones with some lightning audios some time ago.
    LX User Soundy's Avatar
    A20A2 2bbl 5spd 1987 Accord LX hatchback
    Pitt Meadows, BC
    Re: Speaker Size
    FYI, Crutchfield lists just about everything you'd need to know about what speakers and decks fit in what cars. Select your car's year, make, model, and body style, and it'll show you pretty much every brand and model that will go in there (they'll sell them to you as well, although you don't HAVE to buy from them).
    They also sell wiring harnesses, adapter kits, etc.
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Re: Speaker Size
    Wow the thread is magicly back on topic.
    Quote Originally Posted by Soundy
    Good post, I think the other guy looking for the GL speakers should use that link.
    LXi User DDRaptor's Avatar
    1988 Honda Accord LX
    Bronx, NY
    Re: Speaker Size
    Well just to add to the info, my Speakers are all 6" front and back. Not sure why. Pictures below.
    I got an 1988 Accord LX with auto Trans i don't know why mine are different size.
    89LX or SE-i(yeah right)
    Pitt Meadows, BC
    Re: Speaker Size
    My 87 Accords have all had 6.5" stock speakers. From my experience, most Civics of the time came with 5.25", but would fit the same 6.5s as the Accords.
    The stock 6.5s' mounting rings seem to be a little wider than most aftermarket speakers' though, and the cone and basket a little smaller and extremely shallow, and the mounting baskets (especially the door ones) are sized appropriately, which somewhat limits the aftermarket 6.5s that will fit without modification.
    Apr 2004
    2005 Subaru Legacy Limited
    New Hampshire
    Re: Speaker Size
    I just did a set of alpine type s's in my 89 LXi. The 6 1/2 alpines up front were a little too deep to fit in the factory mounting brackets. When I took out the factory bracket they fell in a little too deep so the window would hit them. What i did was cut the backing out of the stock braket so the back of the speaker would fall through, but still mount far enough out so the window would open and close. I used the bracket that came with the speakers just so the holes would line up for install. The 6X9's in the rear dropped right in. Mounting this way up front allowed use of the factory speaker grills so everything is hidden and secure. For the two door coupes with more speaker room, the alpines sound great.
    Feb 2007
    88 DX Hatchie
    Re: Speaker Size
    does anyone know if a set of alpine type r's 6.5 would fit in the front of my dx hatch? and would some type of modification be required? i didnt know if the type r's have different depth than the type s
    "The Original White" 88 DX Hatchback
    Mysterious Project Car
    www.myspace.com/tunerplayground
    You won't know what hit you
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    Re: Speaker Size
    In the front. You know there is a plastic busket there? (black) for speaker. You can not place element with a good magnet, unless you cut out botom from thet busket. I did it.
    Thet on the left is modified, on the right is original
    My Build Thread
    Pitt Meadows, BC
    Re: Speaker Size
    I hacked off the entire back of the basket and beveled the inner edge of the ring to fit a set of Quart separates in mine. You can fit just about anything that conforms to the 6.5" form factor in there, as long as it's not too deep. I used to have a set of JBL separates (or at least the woofers from them) that I wanted to put in, but the magnets hit the windows.
    Re: Speaker Size
    Quote Originally Posted by Tomisimo
    wow u cut that really neet i just smashed a home in mine with a BFH
    Banned
    May 2007
    Re: Speaker Size
    Does anybody know the maximum mounting depth for the front door speakers of an 89 LX?
    May 2007
    tennessee
    Re: Speaker Size
    If you happen to do this to your bracket then you need to place something behind the speaker that covers it and protects it from the elements. There's rust on the back of your speakers and it's because you didn't cover them.
    Re: Speaker Size
    Quote Originally Posted by Hans
    theres rust on the back of his speakers because he prolly found them somewhere also why would a slotted piece of plastic save it from the elements of your door lol
    May 2007
    tennessee
    Re: Speaker Size
    The plastic piece is slotted so that the speaker cone can move back and forth. When the cone on the speaker goes forward to make a sound, air must be able to get behind the cone to equalize the pressure around the speaker. If you look at the slots on the plastic piece you'll see that the slots are angled. This allows the air to get in, but keeps water off of the back of the speaker that leaks into the door.
    Re: Speaker Size
    makes sense but its still gona get water on it i know mine haven't rusted yet and they have been in 2 dif cars scenes like 2004 maybe cause there coated with a paint like substance
    Tomisimo's Avatar
    Sep 2006
    Norway/Europe
    Re: Speaker Size
    No man, thet rust is from ather car i take them off, at the J/Y.
    You dont need to cover the element, simply becouse of if You see closer at the bucket, You dont get thet much protection from humidety.
    My Build Thread
    Re: Speaker Size
    even if thay do rust its not going to hurt them
    Apr 2004
    New Hampshire
    Re: Speaker Size
    My door had a 2 inch wide hole in it... no rust when i pulled my speakers out lol.
  1. whats the front speaker size?
    By chanyeehon in forum Interior & Exterior Care
    Last Post: 11-25-2003, 07:39 PM
  2. Speaker size?
    By HostileJava in forum Interior & Exterior Care
    Last Post: 08-31-2003, 05:16 PM
  3. speaker size
    By xaccordx89x in forum Interior & Exterior Care
    Last Post: 08-18-2003, 01:01 PM
  4. Speaker Size?
    By Red88Hatch in forum Interior & Exterior Care
    Last Post: 08-03-2002, 05:22 PM
  5. Speaker size for a 87 dx???
    By 87blueaccorddx in forum Interior & Exterior Care
    Last Post: 07-23-2002, 04:43 PM
VigLink badge
