AcidX,
"Been there done that"
The wire from fuse box coming from Fuel Pump Relay (FPR) is on connector C108 and is Y2(yellow with two transverse stripes).
There are 3 connectors @ the back of fuse box, C108 is above FPR and Intermittent Wiper Relay.
As u look at C108 from wire side, key up, Y2 is the 3rd wire from left on the bottom row.
I didnt like the idea of a switch, cause the thief may find it..
I got a 10A DPDT Kill Relay (KR) and passed Y2 through a NO contact.
I used the other NO contact to self maintain the relay once is actuated. I inserted this one on Bl/Y2 wire on same C108, 1st from right, bottom row.
This Bl/Y wire goes from Fuse-1 to Charge Warning Light (CWL), so when the relay is off the light is OFF (reminds me to turn relay ON!).
KR is manually actuated, after the ignition key is on II..
Here some schematics, hope they come up right..
C108 >---Y2--------o/o--->FP
C108 >---Bl/Y2-----o/o-+-->CWL
+----[KR]--->Gnd
+----|>|--->Igniter (Bl/Y)
where:
-o/o- is NO contact
-|>|- is a diode
+ is connected wires
Good luck!
