Results 1 to 7 of 7
Thread: b20a q:
    hondaman87's Avatar
    88 honda accord DXE-i H/b 91honda accord wagon, 01 gsxr 600
    medford, mass
    b20a q:
    is there a difference in HP ratio between the gold valve cover and the black one or the 87 to the 88 engines, because i know the the engine produce what about 160 hp, so please help
    LX User Versanick's Avatar
    Jun 2002
    1986 Honda Accord LX Sedan (RIP), 1989 (same) RIP, 86 Hatch Lx-i, JDM b20a, Gude headpkg, AEM cam gears/cai, thermal xhst, 2.5/3" lowrd tokico/groundctrl, 17" Seneca whls, hypereutectic pistons, .020" over, 13:1 comp
    Upstate NY
    Nope. Idle controls are different (and, coordinating with that, slightly different vacuum lines in different places, dual butterfly-black vs single butterfly-gold), and you can very easily use a pk2 ECU with the black top (cam sensors in different places, different distributor and exhaust cam sensor units), and a f2k5 tranny on the black vs a b2k5 tranny on the gold (no notable difference there).
    If you have an 88-89 accord it'd be a bit easier to go black top. with an 86-87 accord, it would be easy to go gold top, but anytime you can get a black top, the easy pk2 ECU use is nice (electronic advance ignition versus vacuum advance on the gold top).
    I wish I had a black top, and I have a gold top. No hp difference though. Unless someone knows different. My gold top definitely does its business...
    hondaman87's Avatar
    medford, mass
    Quote Originally Posted by Versanick
    so I still can use the dual stage intake from the 88-89 sohc or as the a20a5 right
    S.Glastonbury, CT
    Either motor is fine just use your Intake manifold and you eliminate all the headaches. If you want to run the prelude ecu then get the prelude distributor and cam sensor or the vacuum advance distributor from a first gen teg with the matching cam sensor. Its really not bad cause there are many options.
    Jun 2002
    Upstate NY
    Quote Originally Posted by RobT5580
    that's a much more clear explaination. listen to RobT
    LX User Civvy's Avatar
    Mar 2004
    18 yr old Prelude, the one with the pop up headlamps. B20 (prototype for the 3g Prelude) ...but in the lighter car, with big brakes
    Pommieland
    Using the electro dizzy and cam sensor from a B20a7 onto my B20a1 would be part of changing to OBD1 rite??
    Is there any advantages of electro over vacuum?
    I imagine its so the ECU is controlling both fuel & Spark? ...Is that an advantage, other than to reprogram the OBD1?
    Jun 2002
    Upstate NY
    I don't know if a b20a7 distributor is obd1 compliant. It would have to be.
    And there's a little bit of power hidden in this. There's nothing particularly wrong with vacuum advance, but electronic is better.
    Not like 20hp better. Maybe like 5 or 8hp better... You could have your ignition timing set just fine, and as long as your vacuums are all put together correctly, you can make the same power. The electronic advancing has the advantage of already-engineered amounts of advance at different RPM. Someone correct me here if I'm wrong.
    So, in a way, yes fuel and spark. And obd1 would be great for many other reasons. A lot of things that run by vacuum, for instance, are run electronically.
  1. trying to fit b20a ac on b20a help need pics and advice
    By mykwikcoupe in forum JDM B18A / B20A Swap Tech
    Last Post: 01-07-2013, 02:11 PM
  2. AUTO b20A TO MANUAL B20A...ECU InFO
    By AccordB20A in forum JDM B18A / B20A Swap Tech
    Last Post: 05-19-2006, 02:57 PM
  3. Replies: 10
    Last Post: 08-30-2005, 01:10 PM
  4. JDM Accord B20a vs USDM Prelude B20a
    By flip888 in forum General Engine Swaps
    Last Post: 04-24-2005, 12:11 PM
  5. Euro B20A -> JDM B20A
    By McNick in forum General Engine Swaps
    Last Post: 09-29-2003, 02:41 AM
