Results 1 to 12 of 12
Thread: Drop Question.
    SEi User halxi's Avatar
    88 LX-i Coupe
    Brighton, Colorado
    Drop Question.
    Ok, so i was looking around for the answer to this question, and all i can really find to it is "your cars going to ride like crap". So heres my question.
    Will the Tokico Premium Performance Struts be alright with the Neuspeed/H&R springs?
    Im planning on buying the 1.5" Neuspeed drop springs, with the Tockico PP Struts up front, and HP Series for the rear. My true question is, will i tear up the struts super fast this way? Im sure its going to be a little bouncy, but im more concerned about killing my struts in 1-2 years.
    Sorry if its already been answered and i missed it.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    No, if you where going lower that 2 1/2" it would be a problem. Should be fine from what I know.
    Jan 2004
    Bucket
    Bay Area, CA
    yah 1.5 inch drop isn't much of a problem, you shouldn't even need camber kits and control arms, just get an allignment.
    3geez for life.
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    Methinks that tokico only makes one 'performance' strut, the hp aka Tokico Blues. While the rear set will be stiff enough, the front won't be. bounce isn't actually that bad, but I'm sure the front set will go faster than the rear, though I'd think you'd be able to get 2 years out of a set, at least. I went almost one year on a set of monroe sensatracs (which are junk for lowering) with my H&R setup and then switched to tokicos. Only drove the car another 8 months or so before selling it, but everything seemed to be holding up just fine.
    Alex
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    If you want to do it properly, no, the Tokicos are not good for the setup. However, considering the availability of proper shocks, cost, and the fact that the springs you picked are softer than the springs with a larger drop, Tokicos will work. They'll last longer than 2 years probably. You might get 4 or 5 out of them.
    SEi User jigga225's Avatar
    Louisiana
    I think you'll be alright. Those springs you want arent THAT stiff. So I'd say do it. I'm on tokicos and DZ Coilovers, and the ride is um...tolerable.
    89 LXi sedan
    West Creek, NJ
    just got that settup with the H&Rs- little bouncy up front- nice firm ride better cornering, nice low stance. good choice. def could use stiffer struts up front though (i used tokico blues all around)
    88 LX-i Coupe
    Brighton, Colorado
    yea, im mainly doing this because ill have around $750 to replace a tranny (hopefully with a 'lude tranny), strut mounts (front), suspension bushings, struts, springs, and still give the guy thats going to help me some money.
    Busted_Blue's Avatar
    Jul 2003
    93 civic
    San Francisco, CA
    just do it. it will probably be tolerable but not the best suspension out there.
    10/Honda/Ridgeline
    NJ
    the springs you got, are the softest springs available and the struts are the same case. It will be matched up right and you wont have any problems with the bounce. as far as the camber issue, normally around 1" to 1.5" (depending on car) drop, you dont need a camber kit. Some 3g owners with 1.5" drop did not need a camber kit after alignment, while some even with a 1 ~1.25" needed one. So its really upto the numbers they pull out at the installation.
    SteveDX89's Avatar
    2002 Mazda Protege5
    New Freedom, PA
    Quote Originally Posted by smufguy
    Not true. The H&R springs are 26% stiffer than stock and the Tokico shocks can take up to 15%. There will be some bounce but it won't be bad. It might not even be noticeable.
    10/Honda/Ridgeline
    NJ
    Quote Originally Posted by SteveDX89
    exactly my point. Its like matching up Konis and Progress springs. Progress springs are the stiffest springs available for our cars. (other one with 2.25" is higher, but the rears are lower, but u get the point).
    The springs control the compression and the shocks control the rebound. So in a day to day basis, you will be matched up fine with the tokiko and h&R.
    ps: unless the dampening rate is really high, which can be achieved from high end full bodied coilovers, getting a perfectly matched shocks/springs combination is really hard, when you look at the numbers alone.
  1. 85 SEi Little Drop.
    By Christofur in forum Classic Honda Pics & Videos
    Last Post: 03-22-2012, 06:57 PM
  2. Goldline 2.25 drop question..
    By sxy86accord1 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 11-14-2003, 02:27 PM
  3. Best Drop for 17s
    By The88Accord in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-31-2003, 08:50 AM
  4. people with 2'' drop on 13's question
    By Mantis88LX in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-14-2003, 06:30 PM
  5. How can i drop my car???
    By Guyver007 in forum Classic Honda Community Chat
    Last Post: 05-27-2002, 07:00 PM
