Results 1 to 8 of 8
Thread: main relay
    main relay
    How about a how-to on a main relay with pics and instructions,location, ect. thanks
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    hmmm...there's nothing to it..
    just take it off...or unplug it and put in the new one...getting access to the bolt tht holds the main relay is difficult..so just unplug the socket and put the new relay somewhr else
    the main relay is under the driver side dash
    u should be able to see it if u remove the fuse cover or from under the dash
    it's mounted on the driver fender
    sorry don't have pic
    accord HB ( metallic green)
    B.C Chilliwack
    If you are wondering how to test it the haynes manual pretty much explains how to test it
    89 efi conversion
    17" katana, lude arms, full 2" exhaust/hollowed cat, Ractive intake, centerforce dual friction, msd coil/wires
    Nov 2000
    Chovies, that's exactly what I did. I got the bolt out to remove the original relay. I tried for something like 30 minutes to get the new relay bolted in and finally gave up. I removed the bracket from the new relay and relocated it.
    Damn assembly line guys must have bolted the thing in before the dash was installed. I got quite a few scrapes trying to put the new one where the old one was!
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    yeap got that trick from carotman i think
    i couldn't even get to the old bracket off
    So i just tape the new relay onto something under there
    wth's gonna look under the dash eh
    Jul 2002
    89 Accord LX-i coupe, Auto
    Missouri
    hey i don't have the manual cause i'm a poor bastard. could u tell me how to test to see if the relay needs replaced.
    "Turn off the television sets and eradicate the slander that says a black youth with a book is acting white." - Barack Obama
    AZmike's Avatar
    Jul 2002
    Tucson, Arizona
    If your car has trouble starting, especially when it's hot out it's more than likely it's your main relay going bad and you should replace it. A new one is about $35 at your local parts store, but they might have to order it. I'm having those problems too. I figured it would be hard enough to pull the old one and test it that I'd be better off to just spend the money and see if it solves my problem.
    Mike
    10/Honda/Ridgeline
    NJ
    http://www.pauldesign.ru/honda/shopmanual.html
    the guy who has the website is Paul Aerodukk from our 3g forum. He worked soo hard and put an original Honda shop manual for free to download. U be a good bastard and download it. :lol
  1. Where is my main Relay?
    By SharkyX in forum 3geez Accords
    Last Post: 10-29-2010, 08:47 AM
  2. I think my main relay is going bad
    By nbx in forum 3geez Accords
    Last Post: 02-05-2006, 07:43 PM
  3. EFI Main relay
    By smufguy in forum 3geez Accords
    Last Post: 07-19-2003, 05:42 AM
  4. Main Relay?
    By kevins89lxi in forum 3geez Accords
    Last Post: 04-17-2003, 07:56 AM
  5. Is it the main relay!? help me!
    By XXFearThisXX in forum 3geez Accords
    Last Post: 04-09-2003, 12:27 PM
