Results 1 to 6 of 6
Thread: hanging idle 89 lxi
    hanging idle 89 lxi
    i have a 89 accord lxi 5 speed when i put in clutch to stop at light
    the idle hangs at 2000 then after 8 seconds it drops to normal
    it does this every time help
    LX User AccordNut's Avatar
    89 LXi 5spd Coupe Sunroof
    Camp Lejeune, NC
    have you checked your ECU for any codes? that should tell you whats going on, definitely some kind of sensor problem
    CAI, DC Header/Strut Bar, Pacesetter Exhaust, NGK Wires/Iridium Plugs, Accel SS Coil, Neuspeed Springs/Tokico Struts, SE-i Alloy Rims/Cupholder/Armrest, Reverse Glow Gauges, H4's, Clear Corners/Bumper Lenses
    SOLD $500 Apr 2007
    how do i check the ecu? i have a code reader but dont think this has obd2
    If you can take the gas pedal and pull back on it and the idle falls back to normal its the throttle cable is too tight. There should be some slack at idle.
    the cable didnt work
    SEi User Deadhead's Avatar
    Jul 2005
    Loveland, CO
    you can check the code by moving your drivers seat forward, and under the seat there is a little plastic cover that you can pop off and there is a light that will blink if there is a code.
  1. Hanging Rear Bumper
    By JBona in forum Interior & Exterior Care
    Last Post: 11-07-2008, 08:28 PM
  2. Wire found unplugged and hanging
    By ahmad89 in forum Carburetor Tech
    Last Post: 06-08-2007, 08:25 PM
  3. a .......hanging.......problem
    By Nate2310 in forum Classic Honda Community Chat
    Last Post: 12-07-2004, 06:59 PM
  4. need help hanging exhaust!
    By 87AccordLXsdn in forum Performance
    Last Post: 10-20-2003, 05:27 PM
  5. Idle acts like a carb return spring hanging up...
    By RedneckRicer in forum EFI Tech
    Last Post: 11-11-2002, 08:41 PM
