Results 1 to 20 of 20
Thread: Rear Disc Brake upgrade LX / LXI to SEI SE-I Conversion
    LX User HaShfIeNd's Avatar
    Apr 2005
    1988 Honda Accord LX-i
    portland OR
    SEi to LXi 4disc conversion?
    not that i'll be doing it anytime soon but curious... is it easy to convert to 4disc breaks on my LXi from an SEi?
    250,000 and counting
    LXi User TheWatcher's Avatar
    Feb 2005
    1989 Honda Accord LX
    Quote Originally Posted by HaShfIeNd
    I assume you mean the SE-i rear disc conversion.
    https://www.3geez.com/showthread.php?t=11356
    The How to sections and FAQs are great, but the real power is using the search engine.
    Peace.
    Apr 2005
    portland OR
    heh yeah i guess i could have searched that one.. didn't relize it would be so popular =>
    1988/honda/accord/Lxi
    nova scotia, canada
    Just did one and found it not to bad to do as long as you have some mechanical ability, you should be alright. The e-brake cables were a pain in the butt but other than that not to bad. I also change all mine flex lines to Stainless Steel and with the rear disc and all SS flex lines, she brakes like a dream.
    Apr 2005
    portland OR
    hmm
    did you take old parts off of an SEi or just buy new parts somewhere?
    nova scotia, canada
    old parts from a SEi
    Apr 2005
    portland OR
    sweet dawg thanks i'll take a look at those
    brake upgrade LX to SEi discussion
    Hey all I got new rotors and calipers for an 89 SEi. I tried to hook them up to the 87 bracket and itīs a different mounting design, the LX uses 1 bolt 1 pin whereas the SEi uses 2 bolts to attach the caliper.
    Well I went back to the UPick and got the 89 bracket and when I tried to attach it to the LX steering knuckle the bracket is too thick (not enough clearance between rotor and the bracket)
    now I'm wondering if one of these two are possible:
    Modify the LX bracket to accept the 89 caliper or put some kind of spacer that will move the rotor (disk) outwards.
    What do you all think?
    Or am I stuck buying the damn knuckle too?
    Eric
    Justin86's Avatar
    Medford, Oregon
    yea the calipers will be much different but I don't see why the rotors won't work porperly. You can not space out the rotor for sure, you might have to grind away some ofthe hub so the caliper fits properly. I used the Se-i hubs so I can't be much of use to ya.
    Oct 2000
    '88 Accord LX-i
    Connecticut
    why try to reinvent the wheel? I would just go back and get the whole 88-89 LXi knuckle and be done with it.
    '88 LX-i Coupe --- LS/Vtec
    Busted_Blue's Avatar
    Jul 2003
    93 civic
    San Francisco, CA
    Quote Originally Posted by 88LXi68
    yup.
    the safety issues involved with making brackets for my brakes is enouhg to get me to just buy the knuckles.
    May 2004
    87 LX // 89 LX-i
    Cleveland, OH
    SE-I conversion
    Quick question. Does anyone have a ballpark figure on what a rear disk conversion would cost if you bought all new parts? Nothing down to the cents but just a guestimated figure. Might be useful to know if people can find some parts and not others, then they'd be able to estimate a cost on the remaining stuff, etc.
    Hash_man_Se_i's Avatar
    Calgary, AB, Canada
    freakin expensive as hell.... Just the calipers were expensive when I had to replace them.
    Honda wants $400CDN for ONE caliper :O... so I got rebuilt ones, luckily I worked at a parts store at the time, but at my cost, it was about $400CDN for calipers, pads, and rotors... so at retail its a lot of money.
    And i dont even want to guess on the control arms and whatnot that you need.
    cuz I've replaced the wheel bearings and balljoints on the lx like 4 yrs ago. Just trying to cut corners, it's also a botch to remove those balljoints at the junkyard. w/e I'll bite the bullet this wkend
    Eric
    new calipers are around $40 a piece from autozone or w/e, rotors abt 25 each, pads about 30 for the set. Plus cores of course. I'll get the actual numbers, I got printouts at home
    Eric
    May 2004
    87 LX // 89 LX-i
    Cleveland, OH
    alright, just did a quick add-up from majestic honda. Not sure if i got everything, but ballpark 650-700+ for everything, minus prop valve and brake lines. not such a good deal
    86LXItooFAST4me's Avatar
    Dec 2003
    1986 Accord LX-i *** 2002 Mustang GT
    Austin, Texas
    i have an entire setup for grabs, still in the box. PM me if interested.
    "Seriously, I have a half o' pack of Rolaids in my dipper" -Stewie (Family Guy)
    Car Pics
    vBGarage
    LX User Trowa's Avatar
    May 2003
    86 Honda Accord EX-i
    Edmonton, AB, Canada
    mine cost me with everything (rebuilt calipers new brake lines and the whole rear suspension from trashed SE-i) for about 600-650CDN which is quite abit since i got the whole rear suspension for 200CDN
    Feb 2005
    Use the search engine.
    Vinny has posted all this information on this thread: https://www.3geez.com/showthread.php?t=31083
    Summary: A hell of a lot of money.
    Peace.
  1. SE-I rear disc brake conversion
    By Xaisk in forum 3geez Accords
    Last Post: 11-30-2012, 09:27 PM
  2. rear disc upgrade for 14 inch rims
    By Not like a rock in forum Suspension/Wheels/Tires/Brakes
    Last Post: 03-09-2004, 07:17 AM
  3. rear disc upgrade for 14 inch rims
    By Not like a rock in forum Performance
    Last Post: 03-06-2004, 02:29 PM
  4. Rear disc brake conversion
    By 86nate in forum Performance
    Last Post: 08-15-2003, 09:38 PM
  5. Disc Brake conversion question
    By Brettmans5 in forum 3geez Accords
    Last Post: 06-26-2003, 09:17 PM
