Results 1 to 8 of 8
Thread: Running car w/o oil
    Apr 2005
    1987 Honda LXI
    San Francisco
    Running car w/o oil
    Damn, I feel like a fool for not checking the oil after my girl had the car for awhile. She forgot to tell me there was a slow oil leak in the car. Next thing I know was that I was driving away from my house two blocks then the oil light went on and the car automatically shut off.
    I don't know if this is a safe measure. I didn't try to restart my car because that will mess it up so I waited for my bro to bring some oil to put in since the dipstick is dry. Still no start....
    Does anyone know what is wrong?? Did I freeze up/lock my engine and have to rebuild or get a new engine?? I know the starter works but the engine is not turning over...there is no movement??
    Can someone advise me what to do. I appreciate all the help I can get. Thanks
    Why Buy New when you can buy used
    Re: Running car w/o oil
    possible your engine is crewed because it was running with no oil
    Jun 2005
    1986 Honda Accord POS tranny
    Edmonton AB
    i drive for a couple hours with the oil light on in my gramps car to no ill effect. if you drove for two blocks then saw the oil light come on, i dont think that would screw up your engine. or atleast not to the point of it not wanting to turn over.
    SEi User Deadhead's Avatar
    Jul 2005
    Loveland, CO
    a lot of the time on cars, the oil light only comes on when there is about 3-4 psi oil pressure. If you are driving at highway speeds or even low speeds... once that light comes on, your engine is toast.
    bobafett's Avatar
    Stock 86 Accord LXi Hatch
    Longview, WA
    yup. if the engine shut itself off, thats not a good sign. likely bare minimum u need a rebuilt (bearings and valve train is probably not too happy).
    if you damaged a lot of the head/cam/crank then hello new engine.
    good luck to you though...
    SEi User B16KILLA's Avatar
    SO,CAL
    I siezed a motor like that in an 87 crx,I took the spark plugs out put about a tablespoon or so into each combustion chamber and let it sit for about 10 minutes,put new plugs back in and fired it up....Oh and it'll smoke for a few minutes and you might want to use a straw or something to get the oil into the combustion chamber.
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Depending on how long you drove the car without oil.
    Hopefully on the situation, you can put oil in the car. (hoping your oil pump will pick up the oil without priming)
    Turn your crankshaft bolt several times. If you can turn it over, there is a chance you can start your car with oil in it. If you can't turn it over by hand, (with a socket on the crankshaft bolt) your motor is locked up & your fuked.
    Edit- as said before, put some oil in the spark plug holes to losen & lube the rings. I've seen cams lock up from oil starvation too.
    LX User azazel_18_2's Avatar
    Feb 2005
    89 Accord LX-i
    Cushing, OK
    If oil doesn't do the job brake fluid will. It shouldn't hurt anything. I have a 56 F200 with the inline six that had been locked up for years. I squirted some brake fluid in her and let it set a little while. Put a wreck on the crank pulley and broke it loose. It ran ok but the rings were shot due to there being no oil. If you are able to break the pistons loose you most likely will burn oil and will need to re-ring the engine. Otherwise, get another engine.
  1. Car running like eh
    By ryan2107 in forum 3geez Accords
    Last Post: 09-05-2007, 03:48 AM
  2. Car running hot
    By my89LXihatch in forum 3geez Accords
    Last Post: 07-31-2007, 10:16 AM
  3. Running HOT HOT HOT!!@#$#$%
    By xbi0s in forum 3geez Accords
    Last Post: 03-18-2003, 09:43 AM
  4. car not running, need help
    By Cloud892dr in forum Carburetor Tech
    Last Post: 02-11-2003, 03:52 PM
  5. running out of gas
    By baron4406 in forum Carburetor Tech
    Last Post: 10-16-2002, 01:50 PM
