Hello all!
There has been some previous discussion about the mythical auto-up feature that the power window switch in our cars might have. According to the shop manual, this does exist. I decided to look into this and opened up a spare window controller. It turns out, all the circuitry for auto-up is there already. In fact, the only missing link is a single wire that must occupy the only unused terminal on the switch connector. I successfully added this feature to my car. It is actually a lot easier to do with an 86-87 switch panel than the 88-89 because the 86-87 switches already have the extra contact installed in the switch body. For 88-89 switches you have to somehow get another contact, drill out the correct holes (which Honda marked actually, just didn't punch out and use). After that, its only a matter of soldering an extra wire to the switch contact and then adding it to the unused connector terminal. I also opted to add a little ridge inside the switch so the AUTO feature is separated from the normal action by a slight "click" if you will, just like AUTO down. This requires taking the switch apart, but is super easy. My first attempt at this was with an 88-89 switch, and I'd recommend getting the 86-87 version because it makes life a lot easier. I'll be happy to answer any questions about this little mod.I'll try to get some pictures up later. This feature is awesome.
