i was skeptical of a remote mounted turbo too until i read this article:
....mounting the turbocharger and
related hardware somewhere dse
in the car, like at the rear of the
vehicle, can be out of necessity
and can drastically minimize
the installation complexity due
to the fact that it's easier to
install.
Naturally, considering such
a setup raises a number of
questions; that's to be expected.
What about potential turbo lag
and pressure drop that would
normally be associatedwith
lengthy turbo plumbing from
the turbo to the throttle body?
How do you lubricate the turbo
with it located so far away from
the engine? How much power
would this kit develop? How
does the boost control work? All
of these, and perhaps others,
are relevant questions, and we
had the same questions when
we first learned of such a
unique product. Heres what
we've learned.
Squires Turbo Systems
(STS) was founded by Rick
Squires in January of 2003, and
it designed and patented the
remote-mounted turbo system.
Squires identified both the need
and the opportunity to use the
benefits of turbocharging in a
much friendlier turbo environ-
ment, and STShas done this
for both cars and trucks. Using
his 20 years of forced induction
experience, a: Squires and his
group developed the STS
Remote Turbo System so that
anyone, regardless of their
application, could experience a
gain of up to 60 percent in
horsepower without additional
or major modifications to the
engine. We thought that this
would be an ideal case and not
every installation would realize
such gains, but one of the reasons
the STS Remote Mount
Turbo System is said to work so
well is because one of the more
detrimental elements to performance
is removed from the
equation: heat.
For starters, having the turbocharger
mounted outside of a
hot engine compartment where
airflow is impeded as a result of
being cramped and nestled
between and behind radiators,
shrouds, gussets and engine
accessories can make it increasingly
difficult for a turbocharger
to operate. Naturally, this does
not make for such a turbofriendly
environment. And this
is especially true when compared
to an install where the turbo has
adequate room and is surrounded
by cool ambient air.
Remember also that unless the
turbo is fed cool outside air, this
is the same environment as a
turbocharger airflow drawn and
processed through a turbo compressor:
hot air going in and
hotter air going out, even with
an intercooler. Cooler air will
also extend the life of the oil, and it is engine oil
that lubricates the turbo bearings.
The unique patented oil system STS developed
also uses the oil from the engine just like a
conventional engine-mounted turbo, but this
system incorporates an;lectric oil pump
mounted underneath the car.An adapter is
installed at the oil filter source, and after the oil
cools the turbo bearings, pressurized oil returns
to the engine via a specially modified cap with a
quick-disconnect fitting at the valve cover. Oil is
cooled on its way to and from the turbo since it
must now travel underneath the vehicle where
the oil line surface is subjected to cooler air. The
same is true for the intake piping from the turbo
to the throttle body. This may seem confusing to
some tuners since most ~nstall plans have been
devised to make intercooler piping as short as
possible (to minimize turbo lag). This train of
thought now differs, as air traveling through IS
feet of intake tubing should make for a turbolag-
prone engine. At least that is the natural
conclusion and has been the result of past experience.
The length of the intake piping can and
does contribute to turbo lag, but this is not the
only conn-oiling factor. as the design of the turbine
itself has a great effect on such delays and,
by design, helps offset lag. Considering that the
air charge still must travel from the turbo to the
throttle body. a properly sized turbo can have
minimal lag. or so we are told. In fact, Squires
compensates for the 2s-percent loss in exhaust
volume associated with a remote mount system
by employing a carefully designed turbine for
each application.
The other question asked by people who are
first exposed to such a system is generally in
regards to intake air temperature. How is this
air cooled. and does it differ from a conventional
design? With the STS turbo system, nearly 90
percent of the intake piping is exposed to the
ambient air underneath the vehicle. and this
exposure acts as a sort of intercooler but with-
out the pressure drop. With an
ambient air temperature of 60
degrees Fahrenheit, the air temperature
at the turbo outlet is
approximately 175degrees. This
cools to a more reasonable temp due
to its journey through the inlet
tubing. The intake tubing is
treated with an HPC coating
that dissipates heat, further aiding
the cooling of the intake
charge. The exhaust piping is
also coated with HPC, which
helps it to retain the heat necessary
for proper turbo operation.
Driving Impression
We drove this system, and
found it to perform exceptionally
well for its intended use. For our
driving impression, we experienced
the performance of the
STS turbo system installed on a
'00 Acura Integra Type-R. Of
course we were skeptical, as the
first thing on our minds when
we climbed into the seat of the
STS-equipped Integra was that
there was no possible way that
the car could respond nearly as
well as an engine-mounted
turbo. We figured the throttle
response would be dampened,
but we were wrong, as power
delivery was almost immediate
with little to no lag. The driving
test consisted of a drag-style
launch from a standstill through
a short straight section and then
through a couple of chicanes
before heading into a long
sweeper. The course was
designed to put the car and the
turbo system through an "extreme case" pace
to exhibit the overall operating characteristics
of the STS turbo system. When launched
from a standstill, the boost in the Type-R
came on quickly, and the car pulled strong all
the way to redline.]ach shift placed you
smack in the middle of the power band
where boost would build quickly-and it
did.
As we drove the car through the chicanes,
the throttle was modulated, and the
engine responded as quickly as you toyed the
throttle. This removed any doubts of dampened
engine (throttle) response, and we were
pleasantly surprised. Heading toward the
long sweeper, we were able to test the linearity
of the STS turbo system by allowing the
turbo to build boost by rolling on the throttle.
Again, the STS system delivered the
goods just fine by building boost at a linear
and predictable manner and without the
unpredictable (Dr. Jekyll and Mr. Hyde)
response of some engine mount systems.
The STS system produced torque reminiscent
of a high-output V-6 (at least thats
what it felt like), and torque delivery was virtually
seamless-the engine continued to
pull until redline, and it did this consistently.
We ran out of road long before we ran out
of power.
Needless to say, from our limited experience,
the STS turbo system rocks when it
comes to power delivery. And the rearmounted
turbo system allows you to enjoy
all the great sounds associated with boosting
an engine without it being drowned out by a
loud, obnoxious silencer (the turbo replaces
this piece of equipment). This setup will get
you noticed, as its just loud enough to raise
the eyebrows of fellow onlookers but not law
enforcement.
Since none of the pollution control
devices that come with newer cars need to be
removed or modified during this installation,
theres no worry about the legality of
such a system. The STS turbo system is
mounted after the catalytic converters, and
since the turbo acts as a muffler, theres no
worry about noise pollution. The STS turbo
system is 50-state CARB legal (CARB
exemption pending), which is good news for
those of you who live in a state where smog
testing is performed. The STS turbo definite-
Iyexceeded our expectations and shattered
any preconceived notions we had about such
a system. And what impressed us the most
was the power output of the STS-equipped
Integra Type-R; with the wastegate set at 10
psi, the engine produced over 300 hp at the
wheels.
The STS turbo system produces great
power and performs better than imagined,
and one of the most appealing aspects of the
system in addition to its performance is its
simplicity. A capable technician can install
the STS turbo system in approximately 4-6
hours, which is a terrific turnaround when
turbocharging a vehicle. Initially, STS only
had applications for select trUcks, sport utility
vehicles, F-body platforms and the new
Pontiac GTO, but by the time you read this,
STS will have kits available for Honda and
Acura applications. Imagine this system
installed in a lightWeight Civic hatchback
with a built engine, ported head and a set of
hot camshafts. It would be a force to be reckoned
with, thats for sure.
STS also offers a variety of upgrades that
will help elevate the level of performance of
its system: methanol injection, GT Turbo
upgrade, intercoolers and CARB-Iegal modifications.
This rather unique turbo system
may possibly be the solution for newer vehicles
that aren't friendly to forced induction
due to their complex fuel systems or
overzealous emission control units. As STS
expands its offerings in the sport compact
market, more tuner enthusiasts who were
previously ignored by mainstream turbocharging
specialists will be boosting with
the best of them. With a price tag in the
$4,000 area, the STS remote turbo system is
competitively priced with many mainstream
systems on the market, only this is one very
unique system.
