I've noticed a thin coating of oil and a few drops along the bottom of my transmission near where it connects to the engine. My guess is that the seal on the flywheel side of the engine is leaking, or maybe it's the shift rod seal. The leak is slow enough that I'm having trouble finding the source. Has anyone had a similar problem? Where did the leak end up being? How big a job is pulling the 5 speed so I can get to the crankshaft seal? Would I just need to pull both half-shafts, disconnect the clutch cable and reverse switch, remove the correct bolts and drop it out?
I'm not planning to do this job right away, but I'd like to know what I would be jumping into when I start.
I'd probably switch out the clutch while I had everything apart too. It's working fine now, but once the tranny is out I figure it's a good idea. The engine is stock so I don't need a lot of grabbing power, I just want something durable that I won't have to mess with again any time soon.
Any advice is appreciated.
