Results 1 to 2 of 2
Thread: carb bog
    Jul 2005
    carb bog
    My 87 automatic accord has recently been bogging between 3500 and 4500rpms, when I back off on the acceleration this reduces the bog. It usually happens after making a stop and having to increase speed to more the 60kph or when climbing a hill. I can always feel it happening but sometimes I have to pull over and let others pass until the rpms increase again. It also seems worse in very wet weather. I have replaced the distributor cap and rotor, spark plugs and wires, pcv valve and air filter. It still remains the same. The vacuum lines seem ok, I also tried carb cleaner. Any other suggestions?
    Apr 2005
    you should try replacing both fuel filters, and if that doesnt work you could test the fuel pump pressure. should be around 3psi i think. I was having the same problem a little while back and when we pulled the fuel pump out the strainer was clogged with dirt. I cleaned it out and havent had a problem since.
  1. carb idle issues caused by carb temp sensor discuss
    By lostforawhile in forum Carburetor Tech
    Last Post: 01-28-2017, 01:51 AM
  2. Help carb gods! I need help! Carb has issues!!!!!
    By 86ccord in forum Carburetor Tech
    Last Post: 03-03-2011, 05:13 AM
  3. Replies: 7
    Last Post: 12-13-2005, 07:16 PM
  4. 87 dx Carb compatible w/ any other Honda Carb?
    By A2B Accord in forum Carburetor Tech
    Last Post: 08-13-2003, 03:20 AM
