rjudgey
Hi Guy's still having problems with my UKDM B20A, i've just gone through everything with a fine tooth come, i changed all the vac hoses with new silicone ones all with a nice tight fit, no ECU codes, modified the TB a little with knife edged outer mouth, knife edged the throttle plate, and put in countersunk screws into the spindle and ground flat onto the spindle. now i've disconnected the fast idle valve selaed it off with some thick card between the manifold and the valve, i also tried disconnecting the IAT, and also the anti stall device is disconnected too as well as the Air con control valve on the side of the inlet manifold. But i'm still getting the engine idling unsteady it just wobbles and stumbles at around 800-1000rpm, and sometimes if you rev it hard for a few seconds it stumbles under 700rpm and then stalls??
Any ideas as this is starting to do my head in now!! Just thinking of ditching the whole thing and putting carbs on or a custom ECU.
UK version only has TPS, IAT, WTS, Map sensor, no O2 sensor or EGR valve in the exhaust manifold.
Thanks Rich.
