Results 1 to 17 of 17
Thread: cant remove stock exhaust manifold
    Mar 2005
    swifts/sprints boosted
    Saskatoon
    I cant remove it because I cant get the heat cover off, the bolts are stuck in there (10mm) and I cant get em out, I ended up stripped the heads on them after using penetrating oil. Now I have 2 bolts holding the manifold in place, bottom center.
    I cant get at them because of the damn heat shield, what am I supposed to do?
    Jul 2005
    1987/honda/accord LX 1988/honda/accord lx-i 5spd/1990 accord ex auto
    scranton,pa
    Craftsman's Bolt-Out sockets
    there like $20.00 for 5
    here's the sizes
    # #2 Bolt-Out™ remover fits Hex sizes 5/16 in. and 8mm
    # #4 Bolt-Out™ remover fits Hex size 10mm
    # #8 Bolt-Out™ remover fits Hex size 13mm
    # #12 Bolt-Out™ remover fits Hex size 11/16 in.
    # #13 Bolt-Out™ remover fits Hex sizes 3/4 in. and 19mm
    here's the link http://www.sears.com/sr/javasr/produ...&bidsite=CRAFT
    it's awalys good to have b/c you'll awalys have stripped bolts.
    take off the downpipe then reach the bolts from under the car. the bracket attatches to the block and to the header, so choose which set of bolts you are going to remove.
    LX User acco-R-d's Avatar
    `89 Accord LXi
    Fort Worth,TX
    ive used the craftsman nut remover(hehehhe) and it worked great. i had trouble w/ removing a bolt on the manifold too. and i stripped it so i had to use the nut remover and it came out.
    Be nice to your Honda. If you or anyone you know harms or hurts a honda dial 1-800-hondabuse.
    Mar 2005
    Saskatoon
    Well I just beat the crap out of it until it came out. But now Im having trouble removing the 2 bung things (EGR and.... something else). I had the top one of the 2 moving a little with a 15/16" wrench, but now its stuck again after about 3/4 full turns. I cant get at the other one with any other wrench.
    Are those bungs neccesary? Can I just cut the tubes and plug them or do they have to be there? Im trying to get the header on, but Ive spent about an hour and half already just trying to get this damn manifold off
    Mar 2005
    Saskatoon
    Fuck it, once again, siezed components hold me back. Arg, I even tried heating it since my last post. I put the manifold bolts back in. Go drive the damn thing off a cliff.
    89 LXi sedan
    West Creek, NJ
    if you want your car to pass emissions i think you would need the egr and the other thing... i just had to turn the egr little by little until it came off... if it gets tough just screw it back in a little and spray some wd40 on it then go back at it.
    Did you remove the radiator and condensor? those help give you leverage and a better angle on the nuts.
    LX User HaShfIeNd's Avatar
    Apr 2005
    1988 Honda Accord LX-i
    portland OR
    speaking of which, does anyone know where one can get new studs and bolts/spacers? heh..
    250,000 and counting
    Blkblurr's Avatar
    Dayton, Ohio
    Majestic Honda
    Blkblurr's Avatar
    Dayton, Ohio
    With all the Hondas i've owned, i've never had a stuck or frozen bolt or nut with the exception of the damper fork carriage bolts. When I rebuild the head, the exhaust manifold nuts came off with little effort. My flexpipe came off the same way. My car had 230,000 miles on it when I did both of these. Is this normal to not have frozen bolts/ nuts?
    My cat bolts were seized on the muffler side but on the header side they were fine.
    Mar 2005
    Saskatoon
    Depends on where the car was driven, here in canada theres brutal winters and alot of salt. Plus 300k on the body/factory engine can cause it too
    Blkblurr's Avatar
    Dayton, Ohio
    I live in Ohio and we have similar winters and use lots of salt and sand on the roads.
    Mar 2005
    Saskatoon
    Well the EGR and whatever the other one is (ill look up right away) are both disabled because of the vacuum line removal I did. So if these remain stuck, I'm just gonna hack them off and seal up the ports on the manifold (if its neccesary)
    EDIT: EGR and that air suction thing... First picture in the second post # 5 and #16
    LX User 88eyeguy's Avatar
    97 Prelude, 97 Suzuki RF600R
    dallas
    holy crap, man. is there a bolt on your car that isn't siezed?
    Four cars (and one motorcycle) in three years and not one with a cupholder...this is the story of my life.
    Mar 2005
    Saskatoon
    Quote Originally Posted by 88eyeguy
    Ive yet to find it
  1. >>>HELP<<< How do I remove stock headunit!?!?
    By propr'one in forum Interior & Exterior Care
    Last Post: 11-20-2006, 01:40 PM
  2. Some new parts + stock exhaust vs magnaflow exhaust video. *640x480* pictures
    Last Post: 06-12-2005, 03:16 AM
  3. how to remove an intake manifold?
    By dysiu in forum 3geez Accords
    Last Post: 10-09-2003, 07:19 PM
  4. does anyone have a stock exhaust manifold?
    By markmdz89hatch in forum Trading Post
    Last Post: 08-27-2003, 02:59 PM
  5. How to remove stock pin stripes
    By Mantis88LX in forum Interior & Exterior Care
    Last Post: 06-14-2002, 01:53 PM
