Page 4 of 4 FirstFirst 1234
Results 76 to 86 of 86
Thread: B18A Dual carb engine picture
  1. #76
    Re: B18A Dual carb engine picture
    indeeeeeed but he wants power and an a20a carb wont do that unless he does a weber conversion and some other mods
  2. #77
    surely some quad carbs would be easier to attatch to a a20/b20 head than they would be to a b18a head? the spacing between intake ports look quite gay on the b18a
  3. #78
    why doesnt he just put some twin carbs on the stock twin carb maifold then
  4. #79
    the more the merrier :)
  5. #80
    Feb 2009
    Honda Accord CA2 1988
    so i guess better wait for a h22a halfcut
    but now for a short term, need to overhaul my b18a first
    btw, thx for ur help guys :)
  6. #81
    does ur b18 run without and knocking or anything from the bottom end?
  7. #82
    Feb 2009
    sry for long time didnt come here
    seems busy right now for my college stuffs
    btw, can you describe ur question with a simple 1?
    sry my bad english, but i seems cant get it T-T
  8. #83
    sweet i meant to say if your B18A was running mint like not making any bad noises like loud knocking from the crank/rods? ive only ever seen one b18a that actually ran the rest have rattly bottom ends
  9. #84
    Feb 2009
    i see
    just like u've said, a little bit noises from the engine
    plus sometimes the idling turn out to be so low, making my car shaking everywhere(suspecting twin carb prob,
    this is why i want to change it into injection in the 1st place)
    ah, 1 more thing is the noise that came from the carburator(also?)
    it's like "ktang ktang ktang" just like when u put a screw into the inlet(but nothing found)
    i think got something loose from the air inlet part bcoz when i hold the carburator, it's stop making noise(nvm can be solved when i have a time)
    i'm the only 1(that i notice) in my local area that using this ca2
    my friends(who r using later model of accord n civics) keep telling me to put in the h22a or b16a
    yeah easy for them to say (-_-")
    overall, ok but need to replace the lower arm
    it give me a bad sound since 4-5 days ago
    dunno if i can find it in here, hope so
  10. #85
    carotman's Avatar
    Montreal South Shore
    I just noticed that the B18A intake manifold gasket is similar as the B20A3 but upside down
  11. #86
    carotman's Avatar
    I found better pictures of the B18A Intake manifold on Yahoo Auctions. Obviously, the seller didn't know what he had and labelled it "B20A".
    This is clearly a B18A manifold.
    Notice the square ports and stud spacing. This is really the same thing as a B20A3
ID:	6735   Click image for larger version.
  1. Found a donor car! 5 speed B18A dual carb 3G
    Last Post: 04-17-2007, 11:19 PM
  2. Where to get a B18A dual carb motor ?
    By tightwhitelx in forum JDM B18A / B20A Swap Tech
    Last Post: 01-13-2006, 04:25 PM
  3. Accord/Vigor JDM Dual carb B18A picture
    By carotman in forum General Engine Swaps
    Last Post: 08-19-2004, 10:14 AM
  4. pic of a jdm b18a dual-carb
    Last Post: 12-07-2003, 06:58 PM
  5. b18a engine in a dx accord HB
    By 87accordHB in forum General Engine Swaps
    Last Post: 01-22-2003, 03:53 PM
