Results 1 to 6 of 6
Thread: Rear Disc Brakes.
    May 2004
    Rear Disc Brakes.
    Ok, question -
    a '94 Integra uses the same rear disc rotors as an '89 Accord SE-I. Why can I not just swap the Integra rear rotors/calipers into the Accord? Might I need a custom backing plate/bracket, or no?
    Anyone looked into this? If not, I'm going to.
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    May 2004
    Only one thing in there about Integra rear discs, and only that it 'won't fit'.
    I doubt it has even been tried. The rear wheel bearing hub assemblies are THE SAME. The rotors are THE SAME. Christ, the calipers look extremely similar, and the only difference I'm seeing, is in the caliper bracket!
    A20A1's Avatar
    Sep 2001
    I thought they were talking about the civic not fitting... Carrotman said the teg rears are the same. The guy asking the question in the thread asked about the teg but then asked about the civic as the donor, which makes no sense.
    What about these parts?
    - Proportioning valve
    - Knuckle
    - Control arms
    - Trailing arm
    - Heat shield.
    shepherd79's Avatar
    Falling Waters, WV USA
    well, all i have to say, do the swap and tell us if they fit. No one here tried to swap rear suspension from teg.
    May 2004
    I don't want the whole rear suspension. That's making it overly difficult.
    All you need are -
    Backing plate
    Rotors
    Caliper Carrier (bracket)
    Caliper
    lol.. I will do this in the coming weeks... we'll see how it turns out
  1. Rear Disc Brakes
    By Xaisk in forum Wanted
    Last Post: 09-05-2011, 06:31 AM
  2. rear disc brakes
    By Nik247 in forum 3geez Accords
    Last Post: 06-19-2009, 06:58 PM
  3. rear disc brakes
    By Chuoiz in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-15-2007, 10:27 PM
  4. SE-i rear disc brakes
    By $40089'accordproject in forum Suspension/Wheels/Tires/Brakes
    Last Post: 02-03-2005, 01:31 PM
  5. Rear Disc brakes
    Last Post: 05-27-2004, 06:22 PM
