Results 1 to 9 of 9
Thread: 1988 accord dx problems
    hey i'm about to buy this 1988 accord dx 5 speed ,ok lets start ,when you drive the car there is a noise coming from driver side wheel or someplace like is rubbing on something i think is the bearing anybody had a problem like that where i can get the bearing or it may be an axle where i can get that,and the other problem with the car is that its leaking oil from distrubutor o-ring is that a big job anybody have pix how to do it and where i can get the o-ring and one more think i have to add the car has 177000 miles on it ,please help thanx
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    I needed to make a thread about that for this site. Here you go..
    https://www.3geez.com/showthread.php?t=45876
    Here is the axle thread below....If you see the axle or anyting underlined, that means there is a link to it.
    https://www.3geez.com/showthread.php?t=28515
    On the axle, your best bet is get one at O'reillys or parts house.
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    Quote Originally Posted by xbajbusx
    Can you be more specific. When do you hear the rubbing sound? Are you turning, accellerating, stopping sitting still etc.
    when the car is moving it sound like somethink is rubbing against somethink even when u put the car in neutral it still rubs when u make left turn it sometimes gets quiter is there a way to check if its a bearing because its sounds like is coming from the driver side wheel
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    Have you looked at or bent the brake dust shield? Does your DX have front disc brakes? Wheel bearings make a growling sound when there going bad. If it's not your dust shield then my guess would be your axle cv joint.
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    All accords had front disks.
    it makes growling noise i just got the car so i guess its gone be the bearing because they told me when the cv joint or axles are bad they make lots of noise when turning the wheels ,how hard is to change the bearing anybody have an idea pictures how to and where i can get the bearing and how much it costs
    2.0Si User
    May 2004
    1988 Accord DX
    SEMO
    Basically need to take the axle nut off, then take the spindle off. Put the spindle in a hydralic press & press the hub off. Remove the inner race. Pack the new bearings with grease, put new inner race in. Press the bearing in the knuckle using a driver. Install new seal. Don't have pics, not sure on price.
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    I just did mine and the bearings were about $35 per wheel. The brand of bearings I used were NSK. I used the service manual to see how to do it and a large hydraulic press at work to press them apart and back together. The old bearings were in like new condition and it turned out to be the cv joint going bad again in an axle I replaced less than a year ago.
  1. 1988 accord DX
    By silentjay123 in forum For Sale
    Last Post: 10-02-2012, 07:03 PM
  2. New 1988 accord
    By JCox in forum Newbie Introductions
    Last Post: 03-06-2010, 06:11 AM
  3. Replies: 8
    Last Post: 10-20-2007, 04:25 PM
  4. 1988 honda accord engine problems
    By MaTt16289 in forum Carburetor Tech
    Last Post: 03-17-2006, 12:58 AM
  5. 1988 accord dx problems in the moring help
    By xbajbusx in forum 3geez Accords
    Last Post: 09-18-2005, 09:02 PM
