key, the other day i tried to install a kill switch for my battery, but i guess i wired it up wrong. when i turned off the switch, the car kept going off the alternator. I think it may have overcharge the battery, because it soon started leaking. My question is: how do i clean up the battery leakage?
I am going to replace the battery too, and wire the alternator into the circuit, but i'm still needing to clean up battery acid.
Oh, and i blew a few fuses at the same time. Is there a main headlight fuse for all of the headlights under the dash? or is it split up into right and left low beam/hibeam? my low beams don't work, and only 1 highbeam works. All of the fuses look good though.
thanks for the help!
