Results 1 to 19 of 19
Thread: Teg Bumpers???
    '96 BLAZER, '85 ELCAMINO
    chicago, il
    Teg Bumpers???
    I WAS WONDERING IF TEG BUMPERS WOULD FIT ON A 3G. IF THEY DO WHAT YEAR COULD I USE???
    YOU CAN'T CALL IT IF IT KICKS YOUR %$#
    Jul 2002
    a pile of lawn ornaments
    Newtown, CT
    i don't know the answer to your question, however....
    ...if I'm right, the 1st gen Teg was built on the 3G subframe, and as a result should have similar mount points for the front bumper. It won't just be a simple bolt on, it'll take some work, but i think it could work out.
    -Mark D.
    LX User winkie45's Avatar
    1989 Accord Lxi
    Kaneohe, HI
    i was just thinking about that too. my friend has a 90 integra that's sitting in his garage, not running, and the bumper was off the car, and i put it up to my car, and it looks like it would fit if you just cut off a small piece on the top. but, im not certain that it would fit.
    shepherd79's Avatar
    Falling Waters, WV USA
    everything is possible. long time ago i was think about the same question, but i am sticking with stock bumpers.
    Vanilla Sky's Avatar
    1999 Penalty Box
    i wanna grab the corners off of a ist gen teg and fir them to my car... rumor has it that the rear disks (conversion) would swap over too
    Derick
    86 Honda Accord LXI HB 5-sp
    Central California
    All tegs are built off of civic platforms, they have never been built of any accord platform. Pop the hood on one and you will see the 2 bolt strut mounts from the civic platform. And the 1st gen teg share's the solid rear beam axle of the civic as well. The vigor was the first acura built off the accord platform. That being the case the civic is a much narrower car so the bumper are not going to fit.
    Now I d
    LXi User 2Fast_Fiero's Avatar
    1988 RED Fiero GT, 1985 BLACK Fiero GT
    Albuquerque, NM
    Jims, thats where you are wrong, The 1st gen Integra's were build off BOTH 3rd gen accords and civics, The whole front end of my X Girlfriends integra is IDENTICAL to the front end of my Accord, and I was gonna do the same thing, but I also had another thing in mind for the more "Auto Inteligent" people, the newer Honda Civic CRX's are almost the same as the Accord in the front end, (so says Erebuni Corp.) but if it is anything near the right size, a Honda CRX front bumper could be customized from the middle to fit a Honda Accord, you would just have to cut the bumper in half from the middle all the way down, and fabricate a little extention to make it a few inches wider, I had to do this for one of my customers.
    carotman's Avatar
    Montreal South Shore
    The 3g and 1st gen integra aren't build on the same platform..
    The integra uses torsion bars in the front (19mm) while the 3g has regular coils.
    The integra has solid axles in the rear while we have independent suspension
    The engine doesn't mount in the same place
    Why do people think that flip-up lights = Accord 3g???
    I need these parts!
    Central California
    Sorry I'm not wrong, honda doesn't built their cars the way you claim. All teg are 100% civic related and have nothing to do with
    accord platforms other than being made my the same company.
    Why do you think people have to use 2 crx spoilers, the civic platform is narrower than the accord that's why. READ carrotmans POST for a further explanation.
    Doing some research will show you that the track widths for both cars and that the distance between the strut towers is different.
    1st gen tegs were built off the 84-87 civic 2nd gen tegs are built off the 88-91 civic ect, no accord bits period. And if you still want to disagree with me their is a 1st gen teg board out their ya know.
    Now I d
    carotman's Avatar
    Civic, CR-V and Integra share the same platform
    Accord, Preludes and Odyssey share the same platform
    I need these parts!
    1999 Penalty Box
    back then they had some similarities, and just looking at that might make you think they are the same platform
    the accord chassis is also used in the acura MDX and i think the TL
    Derick
    Albuquerque, NM
    I've worked for honda most of my working career...........How long..............4 full years, I had to do this every day, Yes the Teg is more Civic, but YES there are things on it that are compatible with the Accord, and since your calling a ASE Certified Mechanic wrong, I'm gonna call my X over and tear her Integra apart to prove it.
    Central California
    Listen, their's something along the way that you've picked up that is throwing a monkey wrench in your thinking. You must have assumed something that you've taken in as fact. Being ASE Certified isn't going to undo that. Like I said their is a web site just like this one for the 1st gen teg. Go their, I did. Within 2 minutes I have the proof to back up what I'm saying. If I dig deeper it will only back me up more. I will be cutting and pasteing our conversations so far and creating a post in their forums. http://www.g1teg.org/phpbb/
    Below you will see links to scans from 2 different magazine articles that talk about the car. They do nothing but talk about how it is based on the civic. You will not find any reference to accord parts being used in any way.
    http://www.g1teg.org/history/hondatuning1.jpg
    http://www.g1teg.org/history/superstreet2.jpg
    read the last sentence
    http://www.g1teg.org/history/hondatuning2.jpg
    article continues start at top
    http://www.g1teg.org/history/hondatuning3.jpg
    Here are the specs that plainly show it's civic based
    http://www.g1teg.org/specs/
    Now I d
    LXi User 87Hybrid's Avatar
    2002 Chevrolet Silverado, 87 Hybrid Civic, 76 Chevy Blazer, 2000 Jetta, 1985 Civic sedan
    Battle Ground WA.
    Sorry to tell you this but there are no interchangeable parts on between teh 1g teg and the 3g civic. I have been building my civic as long as you have been working for honda. I have owned my 3g Accord for 5 years and my 3g civic for 8 years. My civic is in the process of getting a full 88 integra swapover. None of the parts are useful on the Accord except for maybe the headlight motors, just the motors though and not the housings. The rear bumper off of the teg that I still have at the shop is a good 3" narrower than teh bumper on the accord.
    "AAHHH Teamsters, If only I could be as lazy and surley as a Teamster." Quote by Homer Simpson
    Albuquerque, NM
    I'm just saying that when I look inside the engine compartment of 2 JDM Integra's over where I live and in the engine compartment of my UDSM Accord, I see all sorts of shit that are Identical, The engine, yes thats different, D16 to a A20A, is very different, But things like body components are almost Identical, and why we got into this argument about was about the front bumper. Where things are positioned in the Integra's, I see in the same spot on my Accord. Maybe they were salvage and rebuilt a different way by someone a few years ago, I dunno, I just know what I saw. This Accord is my new car, and its my old car lol.
    1987 Hatch DX
    Well....I don't know what you all are bitchin' about but....... I think the back bumper of the 90-93 integ will fit on the back of a 3geez hatch. I took a tape measure to both bumpers, and they seem to match up. Just some 411 for the Hatchback users.
    carotman's Avatar
    87Hybrid, I guess that you mean the 3g Accord
    MSIAccord_LXi, the enginebay "looks" similar because it's a honda. Everything else will be way off if you take a measure tape.
    I need these parts!
    Battle Ground WA.
    Thanks carrotman I did mean the acccord.
    1989/Honda/Accord/HB
    Poughkeepsie,NY
    im in the process of trying to fit a 89 integra{i think} bumper on my car.....i'll let ya know what happens.
  1. 3g and 2g bumpers
    By charliefowle03 in forum 2geez Accords
    Last Post: 04-10-2012, 10:42 AM
  2. bumpers
    By 1813mdw in forum Interior & Exterior Care
    Last Post: 03-03-2011, 07:34 PM
  3. bumpers
    By Rolin' Stock in forum Interior & Exterior Care
    Last Post: 01-06-2010, 08:52 PM
  4. Bumpers?
    By johnnygo in forum Interior & Exterior Care
    Last Post: 12-07-2008, 06:06 AM
  5. these bumpers?
    By 89AccordHatch in forum Interior & Exterior Care
    Last Post: 12-05-2002, 10:15 PM
