Results 1 to 4 of 4
Thread: High speed control
    Apr 2005
    87 honda accord lxi
    Plattsburgh,NY
    High speed control
    when i am on the highway doing around 72 the car gets real squirelly like if there is a little bump or something the car goes all over the road even if i hold the steering wheel straight... i think it is the shocks... cuz when im at low speeds and i hit a bump i can hear it make noises...
    Alex
    LX User cardoc33's Avatar
    88 accord lxi hatchback
    sf bay area
    lower ball joints
    Check your lower ball joints. If they are worn, it will cause a rattling noise over bumps. May also cause wandering at speed. Jack up the car and grab the tire at 11:00 and 5:00 and shake the 5:00 hand, if you feel movement, it's your lower joints.
    Best Price on Clutch Repair in the Tri-Valley
    http://www.trivalleyclutch.com/3gparts
    OEM quality parts for your 3Gee
    Apr 2005
    87 honda accord lxi
    Plattsburgh,NY
    alright well the rattling also occurs if u jack the car up and then lower it u will hear it.... i just had an alignment and inspection done recently would they have noticed that it is worn then?
    Quote Originally Posted by bigal004321
    Standard front end check,
    1: jack up one side of the car untill the tire is off the ground. The other tire must be on the ground still. I use the jacking point under the doors.
    2: grab the tire 3 and 9 o clock postion and shake/rock back and forth slow at first. might need someone to help look underneath. This checks tie-rods,steering rack etc. start kinda slow and work your way up a little harder. Your looking for loosness. Use common sense of course the steering wheel will move or the other tire may move if you shake the shit outta it.
    3: Grab the tire 12 and 6 o clock. Rock back and fourth.This checks the wheel bearing and ball joints other links
    4: this check might show ball joints/upper link a little better. Use a pry bar under the tire at the 6 o clock pos. pry up look for slop looseness while prying.
    This is your basic "front end check" any good mechanic should know. It works for all makes and models of cars.
    This doesnt really check the struts on our cars since they dont have anything to do with the location of the suspension just dampning.
    I would also look for any broken suspension pieces since your car is from up north rust can attack the frame as well.
  1. high speed breaking and shaking
    By buttaz1 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 10-01-2007, 01:09 AM
  2. High-Speed Performance Review
    By 2ndGenGuy in forum 2geez Accords
    Last Post: 04-24-2006, 01:39 PM
  3. Bad shaking when breaking or high speed!
    By NastyNate in forum 3geez Accords
    Last Post: 10-23-2005, 07:25 PM
  4. Accord 87 carb with high idle speed
    By vasile in forum 3geez Accords
    Last Post: 05-09-2003, 06:46 PM
  5. Strange High Speed qwirk
    By dosh8er in forum 3geez Accords
    Last Post: 10-22-2002, 09:53 AM
