well as the title says the battery light comes on for some odd reason i had the car cheked and they told me it was the alternator so i got that out and i took it to go be rebuilt when i got it back i put it back and hoping the car would startup quickly it didnt so i gave it a jump start that worked so i left the car on for a good 30 min but when i turned it off i tried restarting the car again it did on its own but the battery would get low on the voltage and i got it replaced so with my new battery i started it up and it did it worked fine but after a while the damn battery light came on again the starter also sounded like it need a replacement so i did that and it worked fine and everything but now the light comes on again and after a while the battery dies i am like wtf the battery is new but battery that they gave me is smaller compared to the one i had this one i i belive 550 cold cranking amps while the other one that the car had was 650 cold cranking amps also the light came on cause i would turn on my head lights and my ac unit the battery light just turned on i would turn them off and it would turn off but after a few min the light would come on even after i would turn off my ac unit and head lights could this be cause my new battery is to small or could it be that i need new wiring for the battery cause the ones it has are pretty old and corroted or do i need to replace both????? please help cause i need to get my car running A.S.A.P. i would like a quick response thank you very much in advance
oh yea i forgot to add the car turns on quickly once i give it a jumpstart but after a while the battery light comes on again and when i try to turn it on again the car doesnt and the starter makes a wierd noise but when i asked my nieghbor to give me a jumpstart it it turned on quickly so leaving it at that please i need some responses as soon as possible thank you very much
