If you've done the basic I/H/E to your A20, you might want it to breathe just a wee bit better then it did when it came off the assembly line.
Our secondaries open up at 5,000 RPM. Now with the stock setup, I guess that was just enough to push it that much further down the road. If you want full control and the ability to fine tune your curves out more, this might be a good idea.
Parts Required:
RPM Window switch (
MSD,
Summit Racing, et cetera.)
Wire screwcap, electrical tape, solder, or whatever you want to use to junction your wires. (It's up to you.)
Spare length of wire with a clip on the end.
Note:
Personally, I think the Summit Racing switch is the best value for the buck.
For $20 less then the MSD switch, and the ability to fine tune whatever RPM you want, it's the pick of the litter. No "pills" to deal with, no wire cutting/selecting BS.
First, open your magical black box. Take the four screws out of the rubber float section, flip the thing over. Check out where #13 and #12 run. That's the solenoid we're going to deal with.
Since I'm not sure if wiring changed from year to year, do this. Put the keys in, set her on "ON." Take out the test length of wire. Pull off one connector to the solenoid. Connect the test wire to the exposed pole, and repeatingly tap the other end to a ground point. If the secondary diaphram opens and closes, you found the ground.
If it wasn't that pole, then it has to be the other one. Leave the connector off once you found it, and take the keys out. Disconnect negative off the battery.
Wiring directions for the MSD and Summit units:
Connect the red wire to your coil's positive terminal.
Connect the white wire to your coil's negative terminal, or if you have an ignition box, the tachometer output.
Connect the black wire to a nice and solid ground.
Since it's a closed circuit, we want to hook up the Grey wire to the solenoid. Either reuse the connector from the stock wire or just solder it directly on.
Mount the switch somewhere nice, dry, and safe. Maybe you can find a spot for it in the black box.
Put negative back on the battery, put your car back into the "ON" position.
If you hooked either example switch up right, you should get a status LED on.
Now with the Summit unit, it will be set up to toggle on at 5,000 RPM by default. Set the dip switches at whatever RPM you want. If it needs calibration, check out their PDF. It's pretty simple.
With the MSD unit, put in whatever RPM pill you want.
Fire up the car. After it warms up a little, bring the throttle up a little bit at a time until you hit/exceed your target RPM. Hopefully if you wired it up right (
) it should open them right up, and the status LED should change color.
Now go play with a dyno, use your butt dyno, G-Tech, or whatever method you want to go find the perfect open time for your setup.
Using the BD, I found that my sweet spot is at 4,100.
Depending on whether or not you have a decent cam, your mileage may vary.
Should make things a little more interesting and fun. =)
