Results 1 to 6 of 6
Thread: High idle while warming up, and a 5 speed swap
    SEi User
    Jun 2005
    1986 Honda Accord POS tranny
    Edmonton AB
    currently i am in the process of converting my car into a 5 speed from auto. i noticed that in park or neutral, it will idle at just over 1900rpm while its warming up. when i put it into gear, it will lower itself to about 1200rpm. when its fully warmed up, in park or neutral it will be roughly 1000rpm and about 800rpm or so in gear. when i finish converting it into a 5 speed, if i start it up, would be it idling at 1900rpm? im very busy in the morning, so i wont have any time to let it warm up as i wake up and leave the house very early. i dont want to launch the car every time for the first couple minutes at higher then normal rpms, so if it idles high, is there anything i can do about it?
    1ajs's Avatar
    slurpeepeg
    thats normal!
    SEi User
    Jun 2005
    Edmonton AB
    Quote Originally Posted by 1ajs
    thats normal!
    but when it starts, it would be at 1900rpm, i havent driven standard cars often enough, but isnt 1900rpm kinda like launching the car? i know that if i let off the clutch at higher rpms, it would wear out the clutch a bit faster, but 1900rpm is kinda high dont ya think?
    EDIT: would changing to a standard ECU help it out?
    1ajs's Avatar
    slurpeepeg
    no
    thats about were it idles when warming up if not 200 rpm higher its normal trust me you just take your time with leting off the clutch you just giver her tiny bit of gas and let off and it will idle down the street
    SEi User
    Mar 2005
    swifts/sprints boosted
    Saskatoon
    And I'm pretty sure you need the 5spd ecu aswell...
    Dec 2003
    So Cal, Orange Co.
    get an alarm with remote start and start the car right when you wake up.
    Kevin
  1. high idle problems while warming up
    By mattb247 in forum Carburetor Tech
    Last Post: 03-12-2010, 10:00 PM
  2. Wont drop high speed idle at cold ambient temps
    By FyreDaug in forum Carburetor Tech
    Last Post: 11-17-2005, 08:26 PM
  3. Weber Carb - cold idle fine, warm idle too high - help?
    By it's paid for in forum Carburetor Tech
    Last Post: 02-21-2004, 09:11 PM
  4. Accord 87 carb with high idle speed
    By vasile in forum 3geez Accords
    Last Post: 05-09-2003, 06:46 PM
  5. fluct idle at warming up
    By rutterg in forum 3geez Accords
    Last Post: 12-09-2002, 08:06 AM
