Results 1 to 8 of 8
Thread: Hmm... dissapointment
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    Red face Hmm... dissapointment
    Well in search of extra off the line boost I decided to dig deeper into the advancing system.
    I've used vacuum restrictors before but I never knew how much vacuum they held and how fast they could cycle from 0 - 20 inches of vacuum.
    I figured if the cycling rate was slower the the throttle rate you would still have vacuum advance engaged under hard acceleration. Which turned out to be true, but the maximum flow semed to limit the vacuum signal to about 8 - 10 inches.
    even when I snapped the throttle closed the vacuum signal wouldn't rise. So acceleratiohn ended up worse in some cases.
    but the idea is sound...
    If I used a one-way check valve to supply vacuum to help quicken the cycle time, then a restrictor running parallel to the check valve could be used as a vacuum bleed, so that vacuum advance wouldn't always be on under wot, but would still delay the drop of vacuum to 0".
    if you run a check valve along with the restrictors on another line you can have it so vacuum is applied quick through the check valve and has to escape through the restrictor.
    Eric
    A20A1's Avatar
    Sep 2001
    yeah that was the idea... but I'm all out of check valves.... hey I'm getting the jets and adapter plate for the carb soon.
    i can get u some, what's your addy
    Eric
    A20A1's Avatar
    Sep 2001
    oh dude you're alive... hehe I haven't seen you post nonsence in the off-topic section in a while...
    Still want the weber stuff? paul aerodeck has been asking for the part # for the plate.... the damn thing cost $50. I think hes using the 38mm synchronous. They should mount on the same plate though yeah?.
    Anyways I can just drop by the store and pic a check valve up for $3.00. or I can dunp out my storage bin and see if one fell to the bottom.
    Oh I had a dream I mated a accelerator pump from a holley or eddlebrock to the keihin... and I mande lots of $$$$
    lol
    well I hope they are the same cuz I was going to get a 38/38 but I guess I could start with a 34/36 progressive
    Eric
    Oct 2000
    '88 Accord LX-i
    Connecticut
    A20A1 I think its time to convert to 5spd to help off the line.
    '88 LX-i Coupe --- LS/Vtec
    A20A1's Avatar
    Sep 2001
    Oooooookay... had some fun running in and out of checkers getting vacuum "T" fittings.
    Well anyways I hooked it up and it's sligtly better... Slammin the gas vacuum drops to about 2" and then slowly goes to 0"
    The delay is almost enough to cover the low vacuum from my high duration cam at low rpms.
  1. Cupholder dissapointment...
    By accordlx in forum Interior & Exterior Care
    Last Post: 09-05-2007, 10:31 PM
