Results 1 to 4 of 4
Thread: so i searched...and searched again...
    LX User kaltenacht's Avatar
    1987 Honda Accord LX-I 4spd Automatic.
    USA
    Ok I actually ran like three searches on the forums before i decided to post, so please no flames!!!!!! i tried! hehe kk, any way, ive been wanting to fix my light inside the car for sometime now, cause most of the little bulbs dont work... for example, none of the lights on the heater control seem to be working... so my question is, i want those led blue bulbs, where can i find them to buy? what do i need to look for? second, if im trying to figure out how many volts are being sent to those bulbs, cant i use a voltmeter to check it with? ne help would be great, even if you can point in a direction of a better search...
    I searched
    LED
    LED Gauges
    LED Bulb
    HELP!
    "I contend that we are both atheists. I just believe in one fewer god than you do. When you understand why you dismiss all the other possible gods, you will understand why I dismiss yours."
    SEi User racerx's Avatar
    May 2003
    87 Honda Accord DX
    Colorado Springs
    yeah, one of my friends bought some blue LED's on eBay. He got 2000 bulbs and 2000 resistors for about $30. Don't even bother going to radiocrack for these things. They'll charge you $3 per bulb.
    Use a voltmeter to test for power. One of the easiest things you can do is just put a wire on the output side of one of your fuses. I had a few wires coming out of my fuse box... but if you zip tie them up and out of the way, it's totally clean.
    Then just find a suitable ground. Put the positive wire on the positive lead on a voltmeter, and keep touching random bolts until you get power. There's your ground.
    Just to let you know, though, the lights not working could be a sign that your lighting relay is bad, or the lighting switch (the one on the steering rack) has a short. That's what happened to me. There was a short in the switch, which fried the relay, which fried a fuse, and it took me ages to figure it out...
    www.stein-photo.com
    born to XLR8
    Blkblurr's Avatar
    Jan 2004
    Dayton, Ohio
    Check to see if you have voltage to the current bulbs in there now. You should have 12V if the car is not running. 13.6 or so if it is. You need to put a resistor in line with an led to limit current going through it. Put a 510 ohm or so 1/4 watt resistor in series with each BLUE led. I get my led's at superbrightleds.com. The higher the mcd rating the brighter the led. You should be able the use the existing wiring that powers the current bulbs to power the led's. Blue and white led's are more expensive than others and require a different value resistor. Also led's have polarity. You must connect the + and ground to the correct lead. Hope this helps
    USA
    Helped out alot actually, but i didnt think id have to put resistors in line with the leds... thats ok though, cause hell i can figure it out. thanks for the name drop of the website, i was trying to search around for some internet sites!!
  1. VW lip??? I searched
    By da9 in forum Interior & Exterior Care
    Last Post: 03-16-2010, 04:25 AM
  2. searched already... LCA's??
    By crazykamper in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-13-2006, 11:11 AM
  3. searched with no luck
    By crazykamper in forum Interior & Exterior Care
    Last Post: 06-04-2006, 11:12 PM
  4. ok ive searched weber install q's
    By mykwikcoupe in forum Carburetor Tech
    Last Post: 03-06-2006, 08:41 PM
  5. i searched .. but didnt know what to type lol
    By wikkedv15 in forum 3geez Accords
    Last Post: 03-31-2003, 05:31 PM
