Results 1 to 20 of 20
Thread: Pacesetter v.s. S&S?
    May 2004
    1989 Accord LX-i coupe
    NJ
    What flaws do these headers have verses one another? Who is running the S&S headers at this time? What kind of power gain could i expect to see if I installed one or the other? These questions and or comments would be alot of help to me. Thanks
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    Only one person that I know of (strugglebucket) is using the S&S. The two different headers vary drastically in their cots. Pacesetter is cheap (~$150 or so) and the S&S is twice that. Do a search for pacesetter and read reviews since many people have them here.
    Alex
    May 2004
    NJ
    Yeah i have been reading about the pacesetter for a while and most people have them but they talk like they are not worth getting. If the S&S is way better than the pacesetter header i would spend the money and buy it.
    Apr 2004
    88 LX, 17"x7.5" Enkei 205/40's, Custom fabbed Seamless body front to back, shaved trunk, waiting for 3-Stage Candy paint to be applied
    Canada
    I've got a Pacesetter and no complaints here....Noticable improvement in power band...nice pull from Mid to Peak Rpm....More driveable power
    Dec 2003
    Millington, TN
    PaceSetter Is a good improvement over stock, just get ready to modify it alittle so that your not squeaking down the road. Like having a flex pipe welded in place of the ball joint.
    And replacing the paper/fiber gasket with metal gaskets. Other than that they will give you a grin when after you install it.
    Unless you find someone to part with a DC Sport header.
    I have 3, 1 installed and she is sweet, 1 brand spankin new, and a good used one.
    Good luck
    Phil
    A20A1's Avatar
    Sep 2001
    2006 Chevy Cobalt LS
    https://www.3geez.com/showthread.php?t=37261
    I would like to know that as well... but honestly the S&S seems to have a little more quality in the work.
    Someone said the pacesetter EGR and AS pipe fittings protrude into the primary pipe... which is a bad cause it will be a restriction.
    LXi User TheWatcher's Avatar
    Feb 2005
    1989 Honda Accord LX
    S&S CLEARLY pwns pacesetter.
    Only flaw in S&S is CONFLICTING testimony about whether the EGR lines up correctly (OR NOT). Do a search for the 411 on the EGR (potential???) problem.
    Peace.
    SEi User Acid X's Avatar
    Apr 2005
    Azusa, CA - Los Ang. County
    What do you have to do if it DOESNT line up correctly?
    Feb 2005
    Quote Originally Posted by Acid X
    Don't know. The 3g owner w/ the EGR problem just didn't use the EGR, IIRC. I guess there is no emissons requirement there.
    Again search for the 411.
    Peace.
    Dec 2003
    Millington, TN
    The only way that you can install the EGR is to remove the Dizzy and the thermostat housing at the head and then remove the EGR tube from the EGR valve and start threading tube to header not all the way just enough to avoid cross threading. At this point you'll still have to manipulate the header over the exhuast studs I used a pry bar to help slid it in place.
    After it is seated against the head, bolt the EGR tube back to the EGR valve (loosely). Now begin to snug the bolts alittle at a time until all are snugged.
    Now you'll have to snug down the EGR tube to header until tight. I believe a 22mm 23mm wrench is what I used.
    The power steering & A/C hose will have to be loosened from their brackets and tied out of the way.
    "Note" If you are worried about your radiator remove it. easiest way I know is to remove the shield over the radiator. Just remove the 4 bolts and the hood latch from the shield and the Rad comes right out w/o removing the fans from the rad.
    Romoving the rad will give you all the room you need to install the header w/o any problems.
    Its well worth it.
    Phil
    Apr 2005
    You have the S&S, nsw? Have you had the pacesetter at all and can you tell us how much better the performance is over the pace?
    EDIT: Also, what's a Dizzy?
    LXi User b8er's Avatar
    1987 Ex-i 89 SE-i
    Kelowna, British Columbia
    dizzy=distributor
    -Who needs horse power when you got icy roads and bald tires
    -To drift a car is to create reckless art
    A20A1's Avatar
    Sep 2001
    Is the S&S 50 State legal?
    Feb 2005
    I don't see why not, but you should probably call them to find out.
    If it's DOT legal, and doesn't say anything like "for off road use only", and it's aftermarket or OEM for the car, it will normally pass recon. However, the EGR is going to have to fit. You can't just plug the hole and not connect the EGR and expect to pass recon.
    BTW, just because something is DOT legal, doesn't mean it will pass recon. However, with a header, you don't need to worry about exceptions IMO.
    Peace.
    A20A1's Avatar
    Sep 2001
    I'm asking cause he was in California...
    as for recon, they can forget it. I'll just drive around unregistered like I did in my accord for 3 years.
    Dec 2003
    Millington, TN
    I've had the PaceSetter and now have the DC Sports Header.
    As I stated above the PaceSetter is far better than stock, but you will need to make the small modifications any muffler shop can weld in a flex section and just obtain metal gaskets to replace the fiber ones that come with the Pacesetter.
    Phil
    Feb 2004
    89 accord lxi
    down by the bay
    the s&s is NOT 50 state legal. the egr bung that comes welded to it does not line up any where near stock and it's not even the right size fitting.
    aside from that it's really nice. but don't even try to use it for emissions.
    May 2004
    NJ
    thanks for all the info on the headers guys. I think i'll just go with the pacesetter and see how it works out.
    Apr 2005
    I dont think it even matters if its 50 state legal. If they were to see the header during the visual inspection, which they obviously would, i'd fail anyway, just because it's not stock.
    I'd have to switch it out for emissions anyway, probably.
    But then again, i have a friend who knows a guy...
    Anywho, where would i find some replacement metal gaskets for either header? Is the pacesetter 50 state legal?
    May 2004
    NJ
    pacesetter is 50 state legal
  1. pacesetter
    By CzEcHy in forum Performance
    Last Post: 12-05-2011, 02:38 PM
  2. About Pacesetter.....
    By TsubohachiLX-i in forum Performance
    Last Post: 06-19-2009, 02:28 PM
  3. pacesetter...
    By newaccorddriver in forum Classic Honda Community Chat
    Last Post: 03-03-2008, 12:18 AM
  4. Anything else other than Pacesetter?
    By Listen2myBASS in forum Performance
    Last Post: 09-14-2006, 07:53 PM
  5. pacesetter question
    By b8er in forum Classic Honda Community Chat
    Last Post: 01-14-2006, 08:33 PM
